Power Steering Cooler
by dvanbramer88 » Sun Jul 29, 2012 3:58 pm
Josh's power steering cooler is leaking:
I found the Direct fit part at rock auto for $100 bucks. I also found universal coolers for as low as $20.
http://shop.advanceautoparts.com/webapp ... r+steering
My question is, should I just save the money and rig up the universal one and put it in a less vulnerable location? Or should i stick with the OEM design? Also, how important is the power steering cooler? Would it be unreasonable just to remove the cooler and get plugs for the lines?
by DirtyBacon04 » Sun Jul 29, 2012 4:14 pm
Well I don't have any intimate knowledge on the necessity of the PS cooler, but I wouldn't ever risk using a "universal" part on my cooling system. If ya got the dough to invest, Mike's rad armor protect it effectivley. And I wouldn't remove the PS cooler, either. That sounds like a disaster in the making; I can't think of any sensors in the PS reseviour, so you wouldn't know if the temp was too high until it was too late.
by dvanbramer88 » Sun Jul 29, 2012 4:20 pm
I'm working on finding a junk yard cooler first. Junk yard TB's are hard to come by around here.
by chevycrew » Sun Jul 29, 2012 4:37 pm
I am looking at upgrading mine... To a universal that will cool better, but, whatever you do, don't remove it!
by SaltWaterDrinker » Sun Jul 29, 2012 8:03 pm
chevycrew wrote:I am looking at upgrading mine... To a universal that will cool better, but, whatever you do, don't remove it!
I could only imagine what that would do...
Its been leaking a significant amount; its really making a mess more than causing a problem - however, I don't want to let it go too long and waste money on fluid, nor do I want to make it worse on a trail somewhere in Jersey or our local spot and be SOL.
For history - the initial damage was from the previous owner - something I was not made aware of at the time of purchase. I imagine, however, I ended up making it worse at Materials when I was doing a climb without the bumper cover a couple of weeks ago. My trip to Centraila must have gotten it to the point of leaking the way it is now. :facepalm:
SaltWaterDrinker
by chevycrew » Sun Jul 29, 2012 9:08 pm
I will try to do my research this week and figure out if its safe to sell my stock one.
by gotspeed1 » Sun Jul 29, 2012 9:12 pm
DirtyBacon04 wrote:Well I don't have any intimate knowledge on the necessity of the PS cooler, but I wouldn't ever risk using a "universal" part on my cooling system. If ya got the dough to invest, Mike's rad armor protect it effectivley. And I wouldn't remove the PS cooler, either. That sounds like a disaster in the making; I can't think of any sensors in the PS reseviour, so you wouldn't know if the temp was too high until it was too late.
I've been running a universal one from Summit for about three years now with no problems.
gotspeed1
by dvanbramer88 » Mon Jul 30, 2012 9:04 am
Thanks for the input. Where did you mount it?
by SaltWaterDrinker » Sat Aug 04, 2012 5:07 pm
Aftermarket installed and running well.
SaltWaterDrinker
by v7guy » Sat Aug 04, 2012 7:43 pm
Some of the road race fbody guys are using one from bakers percision. it's cheap and it cools fluid that's turnin 11 inch wide tires over and over. I would guess it would probably do the job for cheap.
http://www.bakerprecision.com/trucool.htm
by gotspeed1 » Sat Aug 04, 2012 9:16 pm
I bought a 1" x 36" pice of steel, mounted the cooler to that, and bolted it up to something in front of the radiator. I don't remember what it was, but I kn ow it was a solid mount. I also had to extend the lines.
gotspeed1
by dvanbramer88 » Wed Aug 15, 2012 6:06 pm
We ended up getting a small aftermarket one. Had to extend the rubber lines. We mounted the cooler in front of the radiator. See Salt's pictures/posts.
