8.6 rear end, How can I tell I got the right one?
by rob03tb » Fri Jun 15, 2012 7:21 pm
I looked at some of the other posts that talk about the differences between the 8.6 and 8.0. Out side of some minor diff cover differences is there anything else? Part number to look for?
Out side of counting the input revolution to wheel revolution, is there another way to know for sure I'm getting a 3.42 ratio? the axle is already out of the vehicle so I want to make sure I get the correct diff.
by the way, one day they quoted me 250 then 350 another time. they have more than one, if anyone is interested I can give the contact info.
rob03tb
by bartonmd » Fri Jun 15, 2012 8:42 pm
Let's see if these work...
I don't see anything to distinguish, but here are some pics of the 8.6 that may help if somebody will post an 8.0"...
by Rob93 » Fri Jun 15, 2012 10:48 pm
Not sure about tags to tell you but the gear ratio is the ratio between the teeth on the ring gear and the teeth on the pinion. If you really want to be sure you can pop the cover and count
Rob93
by rob03tb » Sat Jun 16, 2012 12:17 am
That's perfect, I'll print it out and take it with me tomorrow to the junk yard.
rob03tb
by bartonmd » Sat Jun 16, 2012 4:09 am
And when you pop the cover to count teeth, you can measure the ring gear. That's all i know...
by Rob93 » Sat Jun 16, 2012 11:06 am
^ This as well. Does anyone know how the axle shafts compare?
Rob93
by The Roadie » Sat Jun 16, 2012 11:36 am
Axle spline count changed - 28 splines on the 8.0" version. 30 splines on the stronger one.
by Rob93 » Sat Jun 16, 2012 1:42 pm
Same diameter?
Rob93
by fishsticks » Sat Jun 16, 2012 1:47 pm
Larger diameter.
by rob03tb » Mon Jun 18, 2012 10:09 pm
I struck out. they had nothing but short wheel base TB's. Went to another yard and found an ext with 3.42 but got creamed pretty good and the axle took a hit. But I found this number under one of the ribs that extend from the center section. 40008140. Not sure if this is a part number for the housing only or it includes the entire assy. They had another rear end from an unknown trailblazer with the same number on it, but I left it there because they could not tell me what TB it was from.
rob03tb
by Karo » Tue Jun 19, 2012 5:07 pm
From the older posts i know that there must be 8.6 marked in the differential cover! It is visable from outside on the right side of the cover. Easy to see..
As i have received the first time a wrong axle, i have double checked this for the second round! :cheers:
KaRo
Karo
