by Opeth » Tue Apr 17, 2012 7:01 am
2006 Trailblazer 4.2I, 74k miles.
I'm going to write a trouble shooting thread since there seems to be quite a few of these pesky misfires plaguing our platform, and as suggested by James. This has been a painful and time consuming process that is still not resolved, now I am left at the mercy of my original selling dealer because of the extended warranty I bought. I will update this as I am from the dealer.
Symptoms started as a slightly out of normal idle that just seemed a little rough, barely noticeable (no surges and stayed right at 600-650 rpms) I figured I should think about doing a tune up with new plugs and TB cleaning. A week or 2 later while sitting in the car wash, the idle seemed a bit worse and next thing I know my CEL started to flash. I blipped the gas and it went away.
New ac delco plugs 41-103 were ordered and installed that same weekend which was two weeks ago. All gapped carefully to .042 and all coils were handled gently, and plug boots were reinstalled with dielectric grease.
Upon first start up, truck seemed to have a smoother idle but later in the evening the CEL once again started to flash and the idle seemed quite poor again. Drove the truck home, and upon parking the CEL stayed on resulting in a P0306.
I swapped coil pack #2 with #6 and plugs from #3 to #6 to rule out either of those two. Disconnected the battery overnight to reset the PCM, CEL returned shortly after the truck had warmed up the next day with P0306 again. Ruled out plugs and coil packs.
Stumbled upon a post elsewheres about a member who had this same issue and found that his intake manifold bolts were loose near cylindr #5 & 6. I discovered the same issue, they were maybe hand tight at best, tightened them down but CEL still remained going on and off.
Last Friday stumped and not wanting to throw away money at parts I didn't know would fix the issue or not, I gave it to my dealership since I had bought an extended warranty which I was lead to believe was "bumper to bumper."
After an initial first improper diagnosis by them stating it was a bad coil even after i told them it wasn't, I was called Monday and told the compression on #6 was more than 70% lower than the rest. They couldnt say what the culprit was nor knew if the warranty company would cover this and needed authorization to do a tear down to diagnose the issue and would most likely have to have the claims rep come and look at the head.
This is where my truck stands, hopefully I will hear something today and will update this as I am.
