Found a lot of play where the passenger front axle goes into the disconnect. Pulled the axle out temporarily until I had time to get into the disconnect. I did see fragment evidence that there was once an axle bearing in the disconnect at one time. Found a spray paint cap that worked great as a dust cap while the axle was out.
So today I pulled the disconnect apart (after reading James's great how-to on operation and rebuilding. I already had all new seals, bearings and two of the three thrust washers in hand to do the rebuild. Now I'm seriously wondering if I should bag the rebuild and go with an ATP or junkyard unit.
What I didn't find ...
any of the rollers from the axle and outer gear bearings
much of anything that actually resembled grease. Most was the consistincy of hard wax.
What I did find ...
decent sized wear grooves in the bearing surface of the outer gear
very worn outer and inner thrust washers (middle one looked pretty good)
a cupped outter thrust washer (as in no longer flat)
an actuator fork with rather worn ends
a new "taper" on the outer third of the axle bearing race
an outer housing with no bosses to stop the thrust washer from spinning
a couple pics ...
new outer thrust washer and footprints of old bosses to stop it from spinning (??)
worn end of fork (should be full size rectangle)
I mentioned that the outer thrust washer was cupped. Whether it spins or not, it is cupped to a nice fit to match the inside of the housing. If I install a new thrust washer, I'm afraid it will only be riding on the outer edge of the washer and if it spins, it will start milling a pocket in the housing.
When I dry fit things back together with the old parts, the two gears could separate enough for the middle thrust washer to slip out of its little pocket between the gears. With two new thrust washers and flipping the inner one around (worn pocket toward housing), things stayed in place. For now, I greased it all up and put it together that way - with a new bearing pressed in for the outer gear. At least the inner gear and bearing are supporting the intermediate shaft. The outer gear is just a little sloppy in the new bearing, but it shouldn't be spinning. Actually the viscousity of the grease could cause it to spin, but the collar won't be engaging and driving it. Passenger axle not installed.
So back to my questions.
Will a "spinable" outer thrust washer be a problem?
Will a axle bearing be sufficiently supported on the inner 2/3 of the race (since the outer third isn't a tight fit to the bearing anymore)?
Is this worth rebuilding since a new outer gear is $87, a new fork is $50 and new seals are $40ish?
On a good note; the disconnect came out with just some hand wiggling and went back in the same way. No PBlaster. No prying. No hammering. No broken case.
