hobbstisdaman wrote:And the nozzle just pops off? I didnt want to break it
The hose is under the plastic cover, you have to remove the wiper arms, a few 10 mm nuts, and the antenna, and it will just lift out. The nozzles just snap into the plastic, and have a hose barb on the end.
Be really really careful when you take them off, I had the same problem with my 07, and ended up breaking the nozzle off... The only place to get replacement ones is the dealer, and are $25 a piece, unless you get some of the universal ones, but they are quite large and horrible looking.
You could try a pin to clear it out, or pull the line and disconnect it on the passenger side and soak the nozzles in water.
