Shuddering
by Blask3 » Wed Jan 05, 2011 8:13 am
When I am driving I get a shuddering sound and a vibration in the front end. I do not think it is a warped rotor or anything related to the brakes. Is it possible that it could be something with the axle or the transfer case?
Jim Blask
GIT-R-DONE
The only Lifted TB in the Valley
Blask3
by Trail X » Wed Jan 05, 2011 9:42 am
Could be any number of things. There's some extra information that we need.
Does the frequency change with vehicle speed, or engine speed?
Is there a resonant speed that the amplitude is higher?
What is the approximate frequency (how many times does it shudder a second)?
Do you only notice it when in gear and driving?
Is there anything you do that makes it worse? IE: Turning, braking, accelerating?
by bartonmd » Wed Jan 05, 2011 9:46 am
I would really make sure your wheel adaptors and/or wheels are on tight...
by Blask3 » Wed Jan 05, 2011 9:59 am
The sound accelerates when the vehicle does, it is only there whe the vehicle is in motion not at idle. Turning makes it vibrate in the steering. It slows to a stop when I brake and the vehicle stops.
As far as the wheels, I don not have adapters but I will make sure the wheels are on tight.
Jim Blask
GIT-R-DONE
Blask3
by bdp1978 » Wed Jan 05, 2011 10:11 am
Hard to diagnose without checking the components, but I had both of these symptoms in the past.
Vibe in the steering wheel that I could also feel in the floor = Bad Wheel bearing.
Shuddering with a vibration noise in the front = Bad CV joint.
These are only my personal experiences.
bdp1978
by Blask3 » Wed Jan 05, 2011 10:58 am
I am going to look at the cv joint because I think the boot may have ripped apart. I imagine that it is dry and probably needs to be fixed.
Jim Blask
GIT-R-DONE
Blask3
