I'm pickin up bad vibrations...
by Mooseknuckle » Thu Mar 03, 2011 2:04 am
ok good call will do.Thanks
I don't dial 911
Mooseknuckle
by HARDTRAILZ » Thu Mar 03, 2011 2:08 am
Good luck those lights annoyed the crap out of me. Ended up swapping the sensors side to side and it fixxed it. :hissyfit:
by Mooseknuckle » Thu Mar 03, 2011 2:29 am
yes i know i now have three started once i had to geta new PCM cause the clips broke on mine so then I need a crank variation relearn(engine light) went to autozone found it was two codes po315 and po171 one was the crank and the other is an O2 sensor I have yet to figure that out. Anyway i have the abs,engine and stabilitrak lights on,I'm light up like a freakin xmas tree...ahh :o
I don't dial 911
Mooseknuckle
by Mooseknuckle » Sat Mar 05, 2011 3:24 am
ok got the truck aligned and rides like a champ. Got the engine light to go off by doing what James said and taking everything apart like I'm cleaning the throttle body and make sure everything seated well. I did just that. put a little diletrical grease where it was needed and cleaned the MAF sensor with maf cleaner. I also took the wheel apart that Mario and I just replaced the cv shaft so I could get to the brake sensor. it had a lot of grease on it so I removed a little made sure it was clean and back it went put it all back together. Now when the truck is running in park when I step on the brake I get a click noise each time in the center consule. W hat the hell is that and should I be worried? obviously it has to do with the sensor..
I don't dial 911
Mooseknuckle
by Gordinho80 » Sat Mar 05, 2011 8:35 am
In park, click in center console when braking, is the shifter lock disengaging...
by Mooseknuckle » Sat Mar 05, 2011 12:58 pm
your the Champ thank you!
I don't dial 911
Mooseknuckle
