really need your guys help with my trans!!!!!
by tarsh » Thu Oct 03, 2013 6:23 pm
Haaa. What's that do for me anyways?
Take the path less traveled
tarsh
Name: Nathan Schroeder
by Trail X » Thu Oct 03, 2013 6:59 pm
Read the link I posted. But to fix your tcc flutter, it replaces the iso-con valve with a design that gets rid of the pwm functionality. It lowers temps in the trans and improves efficiency.
Your other option is a remanufactured valve body.
by tarsh » Thu Oct 03, 2013 8:40 pm
What's iso-con and pwm?
tarsh
by mikekey » Thu Oct 03, 2013 9:19 pm
Good luck buddy!
by v7guy » Thu Oct 03, 2013 10:23 pm
tarsh wrote:What's iso-con and pwm?
It's a little valve in the transmission, not a big deal to change just a good bit of labor. James and I have both wrote it up. It would probably make sense to just toss in a shift kit.
by Trail X » Thu Oct 03, 2013 11:06 pm
Iso-con stands for isolator/converter. Its the valve that controls pressure to the torque converter clutch.
Pwm is a pulse-width-modulation pressure control of said clutch, via the valve. The replacement valve in the shift kit gets rid of the pwm functionality, and essentially turns it into an on-off switch. Full clutch pressure, or no pressure.
by Trail X » Thu Oct 03, 2013 11:08 pm
by tarsh » Thu Oct 03, 2013 11:36 pm
Crazyness...
tarsh
by navigator » Fri Oct 04, 2013 11:18 am
I think it is cool that you can get step by step instructions and online support for basically free.
by tarsh » Mon Oct 07, 2013 4:58 pm
So I did remember to test it in 3 and yes indeed it fluttered. How much of a pain is that shift kit. Its decently cheap. I'm just not a mechanic. I can fab and do the easy stuff. But I'm not one to dig int a trans or motor.
tarsh
by Trail X » Mon Oct 07, 2013 8:53 pm
You saw the pictures in the link. Its not that complicated. Just follow the directions.
by tarsh » Tue Oct 08, 2013 11:34 am
Thanks for the help fellas. I guess I'm installing a shift hit. Hopefully goes well. Wish me luck. God knows I'm gunna need it
tarsh
by Trail X » Tue Oct 08, 2013 3:00 pm
Plan for a whole day of work. Have a contingency plan of how to get to work if things go wrong.
Worst case, you screw it up, a remanufactured valve body on ebay is like $150 if I recall.
by jonbo2002 » Tue Oct 08, 2013 3:14 pm
Might need more then a day :scratch:
jonbo2002
by tarsh » Tue Oct 08, 2013 4:25 pm
So I gotta make a weekend out of this then
tarsh
by Trail X » Tue Oct 08, 2013 6:54 pm
I guess it depends on how early you start. I did mine in a Saturday and finished in time for dinner. However, I didn't mess with the servo at the time.
by v7guy » Wed Oct 09, 2013 1:28 am
The servo is a bit of a pain with the body lift,I would imagine it becomes difficult without a body lift. That snap ring is a real pain.
by tarsh » Wed Oct 09, 2013 9:51 am
Yippi.. no bodylift for me
tarsh
by dvanbramer88 » Wed Oct 09, 2013 10:24 am
I'm curious, does anybody out there make/sell reman valve bodies with shift kits installed during the re-manufacture process?
I know Jason has been screwing with cars/trucks with the R4/60E for years. I figure he might know.
by tarsh » Wed Oct 09, 2013 10:31 am
Sounds interesting. I'm all for it. There's your million dollar idea man
tarsh
