[Solved] Stabilitrak, ABS, and traction control lights on.
by Opeth » Mon Mar 11, 2013 4:56 pm
Obvious bad speed sensor from that one bearing, whole hub replaced under warranty. I asked about the other issues and said I probably fixed the grounding issue because the codes were not current like the speed sensor was.
I'll see if the lights stay off over the next few days.
by Regulator1175 » Mon Mar 11, 2013 6:39 pm
Opeth wrote:Obvious bad speed sensor from that one bearing, whole hub replaced under warranty. I asked about the other issues and said I probably fixed the grounding issue because the codes were not current like the speed sensor was.
Hmmm, Sounds exactly like the answer I gave you a week ago! :facepalm: :poke: :slap: :cheers:
by Opeth » Tue Mar 12, 2013 9:23 pm
Yes, the speed sensor was bad. +1 for you good sir. But the other codes were set from something else, that ground location was pretty rusted and screw look awful. Lights still off. :friday:
