by arl120384 » Thu Jan 26, 2012 5:23 pm
Ok guys, I have had a chance to run some tests, and go through the flow chart again, and this is what I have come up with.
The chart points to the transfer case. With 4HI engaged and the passenger wheel off the ground, the front wheel rotates freely, and the prop shaft spins. The motor on the transfer case, and the front actuator all appear to be working. However there's more...
When the front axle/tire is spinning, there is a light clicking sound, commensurate with the speed of the tire. With 4WD off, this goes away. I took off the front actuator, and it cycled and appears to work. I manually worked the fork, and it only seemed to give me about 1/4" of play, and while I was holding the fork in, spinning the tire, I received the same clicking. I gave it a pretty good push, and no engagement. This leads me to believe that for some reason, the collar gear is not engaging over the inner gear and locking the front end up, I believe it's stopping short, and barely touching, thus the clicking sound of the gears. However there's more...
A few months ago while getting my new tires, I was looking at the front tires from the back, and I noticed that the front passenger side tire stuck out about 1/4"-1/2" further than the drivers side. at the time I thought nothing of it. Thinking about it now, I am wondering if when I rebuilt the disconnect, the front axle didn't seat all the way in the disconnect assembly. It seems logical, however you guys have more knowledge of this than me. Could this be a simple, take a sledge hammer to the axle and seat it, or does it require the assembly to be torn down?
That's my story, thanks for the help in advance.
Alex
Mods - Jettstream HID Fogs/Headlights, MarkMC 2.5" Lift, Quad Tail, 265/65 Tires, Sub/AMP, Custom Stereo/Radio, Bravada Disco Collar Gear Install, Cardone Axles, 1.5" Spacers
Future - Raptor Liner Rockers/Bumpers, LED Exterior/Interior Lighting
