Wiring and warning light questions.
by chevycrew » Thu Feb 02, 2012 8:22 pm
Ok so after trying a bunch of things I resorted to a more drastic approach.
I tore apart the cluster and installed covers over the stock warning light leds. (ABS and BRAKE)
Added in a new bulb into the brake warning light spot.
Wired in new bulb to ign + at the cluster, and hooked the other side to the park brake applied signal wire (ground) at the BCM.
Now the truck still thinks the lights are on, but I cant see them. When Ign is on and brake applied my new light is on, if driven with brake on I still get the chime.
The only down fall, there is no key on bulb check with my new bulb.
