by The Roadie » Mon Jul 25, 2011 7:46 pm
I bought maybe the 1st or 2nd set of adapters Fred made for the platform, and advised him to never supply thinner than 1.5" thick, because not everybody is going to remember to grind off their rear studs. If he started making 1.3" or 1.4" versions, that's a problem. But it would NOT cause the spacer to loosen up off the vehicle unless improper acorn nuts were used. AFAIK, Fred only ships open-ended nuts.
The typical problem with too-long studs and too-thin spacers is the vehicle's studs hit the back of aftermarket wheels. So the wheel->spacer interface loosens up, not the spacer->vehicle.
Could you clear up all these curiosities by letting us know about the nuts and spacer thickness?
