05 and 06 5.3L Vin M Interchangeable?
by Melaronius » Thu May 14, 2015 7:57 am
Well I threw a rod while doing some drunken mudding a couple of weeks ago. Initially I was just going to get a new vehicle but I can't bring myself to do it. I guess I'm just going to drop a junkyard motor into it now. In my search I've come across quite a few 05 5.3L vin M motors but no 06's (I have an 06). Would the 05 fit in my truck without any issues? Any help would be appreciated.
Melaronius
by Eredin » Thu May 14, 2015 12:50 pm
Should fit just fine. Honestly, any garden variety LM7 should interchange. However, you'll want to source an LH6 to specifically match yours. They're aluminum block, AFM enabled and available from 05-09.
2005 Chevrolet Trailblazer LT
2012 Chevrolet Cruze LT
Eredin
by Trail X » Thu May 14, 2015 2:29 pm
I don't think you'll want to mix anything electronic between the 05 and 06 years, but I don't know to what extent. The 05- and the 06+ use different com bus protocols. If I were you, I'd try to source a 06+ to be sure there are no unforseen electronic communication issues.
by Eredin » Thu May 14, 2015 5:29 pm
True, the PCMs are different, but his harness should drop in without issue onto the 05. I'd be really surprised if it didn't, but I've seen dumber things.
Eredin
by bartonmd » Fri May 15, 2015 11:31 am
The LH6 is supposed to be a basically completely different engine, even though they'll both bolt up.
by Melaronius » Fri May 15, 2015 12:06 pm
So I should just stick with getting the exact motor/year of my truck to be safe?
Melaronius
by bartonmd » Fri May 15, 2015 12:43 pm
'06-'08 TB/voy/9-7/etc. shoould be fine.
by Melaronius » Fri May 15, 2015 1:57 pm
Thanks for all the help guys. Looks like those motor's are pretty hard to find. I'll keep an eye on ebay to see if anything pops up.
Melaronius
by HeavyChevy4200 » Sat May 16, 2015 4:23 pm
You should be able to find a similar year range 5.3 out of a truck or van. Take it down to the long block and add all your components and accessories to it. There will be some wrenching involved but you wont have to find the exact year and model TB or Envoy. Helps the search.
HeavyChevy4200
by bartonmd » Sat May 16, 2015 5:49 pm
