Get some brake cleaner and hose down anywhere you see fluid, hopefully you have access to a lift... If not, life will suck. Spray everything off of the motor, pulleys, PS pump, etc. Drive for 2-5 minuets, make a lot of turns, then see where your leaking from. Just make sure the motor is cold, don't set yourself on fire. Should give you a good idea of where its leaking from. Good luck Sir.
