by Cable810 » Fri Aug 08, 2014 1:15 pm
Stock 17" LTZ Rims Painted black. $320 Shipped Via UPS
Asking $200 shipped for the front diff(GU6 or 3.42 Ratio) Will be Shipped VIA UPS.
Cable810 on Tue Oct 13, 2015 10:57 am, edited 13 times in total.
The
FIRST Solid Axle Swapped Trailblazer in Presque Isle County MI
My
BuildThe Roadie wrote:Research, plan your mods, fund the plan, then GO DO THEM. THEN WHEEL IT.
- Veteran
- Name: Caleb
- Vehicle Year: 2002
- Rank: Offroad Rated
by Moots1288 » Fri Aug 08, 2014 1:16 pm
Brake*
- Veteran
- Name: Moots
- Vehicle Year: 2006
- Vehicle: GMC Envoy
- DriveTrain: 4WD
by Cable810 » Fri Aug 08, 2014 1:17 pm
Jeesh you Grammar Nazi!
The
My
- Veteran
- Name: Caleb
by navigator » Fri Aug 08, 2014 1:56 pm
it might be good to list the gear ratio as well.
The answer to many common lift questions can be found hereMy Build Thread
- Moderator
- Name: Chris
- DriveTrain: 4WD
- Rank: Trail Ready
by Cable810 » Fri Aug 08, 2014 9:57 pm
its 3.42
The
My
- Veteran
- Name: Caleb
by Cable810 » Mon Aug 11, 2014 7:13 am
TTT The front diff has a brand new seal with less than 800 miles on it.
The
My
- Veteran
- Name: Caleb
by Cable810 » Thu Aug 14, 2014 2:20 pm
Ttt
The
My
- Veteran
- Name: Caleb
by Cable810 » Wed Aug 20, 2014 4:21 pm
TTT
The
My
- Veteran
- Name: Caleb
by Moots1288 » Thu Aug 21, 2014 7:22 pm
You should regear it to 4.10s and then sell it, you'll have better luck
- Veteran
- Name: Moots
- DriveTrain: 4WD
by Cable810 » Fri Aug 22, 2014 8:30 am
Yeah I probably would
The
My
- Veteran
- Name: Caleb
by Cable810 » Mon Nov 24, 2014 11:47 am
Added a Disconnect
The
My
- Veteran
- Name: Caleb
by Cable810 » Sun Dec 07, 2014 8:11 pm
TTT
The
My
- Veteran
- Name: Caleb
by djthumper » Mon Dec 08, 2014 3:30 pm
Are you bumping your thread? Have you gotten any bites?
- Moderator
- Name: Larry
- DriveTrain: 4WD
by Cable810 » Mon Dec 08, 2014 11:13 pm
Can't we bump. Though there was a 24 hour rukle. I've gotten a hit on the diff now you need to buy my spare disco
The
My
- Veteran
- Name: Caleb
by Grimor » Mon Dec 08, 2014 11:52 pm
so are the brake cables longer than the standard length TB ones? If so, I'm interested.
Grimor
- Trail-Blazer
- Name: Dennis
- DriveTrain: 4WD
- Rank: Driveway Rated
by Cable810 » Tue Dec 09, 2014 8:49 am
I'll measure when I get home from work.
The
My
- Veteran
- Name: Caleb
by Cable810 » Fri Jan 16, 2015 11:41 am
TTT.
The
My
- Veteran
- Name: Caleb
by Grimor » Fri Jan 16, 2015 9:10 pm
were they longer? lol
Grimor
- Trail-Blazer
- Name: Dennis
- DriveTrain: 4WD
by vaTBguy » Fri Jan 16, 2015 10:21 pm
It would appear he forgot to check
vaTBguy
- Cruiser
- Name: Brandon
- Vehicle Year: 2004
- DriveTrain: 4WD
by Cable810 » Sat Jan 17, 2015 12:00 am
I measured and forgot to post the dimensions. 89" tip to tip
The
My
- Veteran
- Name: Caleb
