ReadyLift is now shipping a kit that provides 2" of lift in the front with 1" in the rear. On a stock Trailblazer/Envoy, this kit brings the vehicle almost level, but still has a tad of rake leftoever. I'm only reviewing the front setup as the rear looks pretty straight forward.
The front features a 1 1/4" tall spacer that bolts up to the outside of the stock strut and provides an overall lift of 2". Note this is different than the BDS kit which is installed within the strut assembly and pre-loads your springs.
For this test I installed the ReadyLift on 'stock' struts and did NOT combine these with my BDS setup. Note, this is their recommendation, too! Combining this kit with other kits is not recommended by ReadyLift! On to some pics...
Top: BDS HD shock. Stock spring. 2" BDS spacer inside the strut:
Bottom: Stock shock. Stock spring. 1 1/4" ReadyLift spacer outside the strut:
Close up. Note, BDS is now on the left, ReadyLift on the right:
ReadyLift installed and positioned within the upper strut bucket. Note it attaches to the strut using stock hardware. However it comes with three studs to leverage all three mounts in the bucket.
Top mounting pic. Note the three studs compared to two on stock struts.
Per their site:
Features & Benefits:
- -Keeps your factory ride - Guaranteed
-Will never wear, break or fail - Guaranteed
-Toughest finish – Guaranteed
-Safest way to lift - Guaranteed
-The highest quality TrailBlazer mild lift kit system on the market
-Allows for up to a 32x10.50 tire when using OEM wheels or offset equivalent with a 1.5" wheel spacer.
