by Trail X » Mon Oct 05, 2015 12:28 pm
You had it just about right KC. Not sure where you got the 5.06" of travel, shock mfg website? Lets roll with it.
Lets assume that at 5.06" of travel, you've got half up and half down from stock stance, giving us around 2.5" of up and down travel.
There are three types of lift blocks: Inside, outside, and combination.
Outside blocks take nothing from your travel, and only offset the whole strut down. This may be fine for 2WD trucks, but for 4WD trucks they can allow the suspension to droop down too far and damage the CV shaft.
Inside blocks take directly from your down travel. So if you get a 1" thick inside block, your up travel would become 3.5", and your down travel would become 1.5".
Combo is what most one-piece blocks are on the market today that replace the upper shock mount. They tend to balance their lift between inside and outside strut amounts to achieve the maximum amount of lift without overextending components of the suspension and drivetrain.
Lets assume that your lift is balanced half and half. A 3" lift block equates to a block thickness of about 2" due to the lever arm (3 / 1.5 = 2). Assuming it is balanced between inside and outside lift, you are losing 1" of strut extension. With the spring in your post also contributing .75" of lift (.5" at the strut), you lose 1.5" of extension in total. This is taken away from your 2.5" of original suspension extension travel, giving you 1" of downward travel from the resting point.
Yes, it basically gains the equivalent in compression travel, now giving you 4" of compression travel (its possibly a little more limited due to the fact that the spring will eventually compress into itself and form a solid, which you want to avoid because it can prematurely damage a spring).
Yes, the setup will be more likely to top out. Its a price we have to pay for IFS where you can't reposition the front diff.
