Looking for rear advice
by Miltman » Fri Aug 21, 2015 11:50 am
Planning on a MarkMC 2.5 lift with 4600 Bilstein on the front but wondering what would be better on the rears. Want something that will smooth citywide but hold up if offrosd. Any thoughts would be appreciated
Thanks
Miltman
by maricard » Fri Aug 21, 2015 2:23 pm
Look over our build. You should read a lot about it. Many use skyjacker, bds, bilstein or avalanche shock.
_____LESS IS MORE_____
Ludwig Mies van der Rohe
maricard
by HeavyChevy4200 » Fri Aug 21, 2015 7:39 pm
I went with the BDS shock as it allows for the extra travel. Oem replacements can or will be near over extension with the lift.
HeavyChevy4200
by TBYODA » Sat Aug 22, 2015 11:50 am
I used the Skyjacker rear shocks N8030. I took a chance and got them from there web in the scratch and dent section for much cheaper. They looked and work fine.
