Compiled RadFlo Height Adjustments & Results
by mikekey » Sun Dec 01, 2013 4:05 pm
Adjusting your Radflo's
SOME SUGGESTIONS:
First you'll need to get these: JEGS Performance Products#555-81800 Steel Spanner Wrench Set
Then you'll need to figure a method that works best for you for adjustments. DirtyBacon had a unique solution that works.
You can also adjust the height on the vehicle.
Prepare to spend some time turning your spanner wrench. :lurk:
HOW TO MEASURE:
Here JamesDowning lists the official measurements to be taken so we have a standard we can all follow. This will allow you to see what others have dialed in and the resulting heights.
JamesDowning wrote:I have the hook of the tape measure grabbing on the mounted-top side of the locking collar, when spun all the way up. Using that method, it shouldn't matter if you're measuring yours by running the locking collar up to the top and pulling tape from it, or jamming the tape end into the shoulder at the top of the threads.
Mine I'd read at 3.5".
JamesDowning wrote:You report the CV axle center to fender height? That would be another good standard of measure for us to use, since it removes tires from the equation. An average of the left and right readings is also best.
Go ahead and post up a photo or your measurements of your results adjusting the height of your Radflo's. Also post up some details, about whether or not you have bumper/armor. :thumleft:
by ErikSS » Sun Dec 01, 2013 5:21 pm
The upper picture is mine. So I'm at 4 3/8". I thought I had settled but new measurements show that I'm still at the 42 1/4" that I was when I stopped turning. I've put about 1,000 miles on them already. (holiday travel) I still intend to reduce mine. Maybe I will try around 4".
I have 315/70/17 BFG tires. The rear are almost new, the front are fairly worn. All of these things play factors in fender height.
by Trail X » Sun Dec 01, 2013 6:35 pm
Can you report the CV axle center to fender height? That would be another good standard of measure for us to use, since it removes tires from the equation. An average of the left and right readings is also best.
Thanks for posting this Mike.
by mikekey » Mon Dec 02, 2013 12:42 pm
I updated the first thread to be a little better detailed, hopefully that helps and folks will start posting their measurements.
Talk about spending some time turning the damn things.
I am going to start at 3.75inches myself since I don't have a front bumper and see where that puts me from the center of the CV to the fender, I'll post up those measurements shortly.
And if anyone is curious, this is where mine (and probably everyones) were set to when I got them:
by HARDTRAILZ » Mon Dec 02, 2013 1:02 pm
So measure from outside of collar to outside of collar.
Measure hub center to fender lip on both sides and average.
Report on bumpers, skids, or other items on fron thet would add or remove weight from a standard load.
I got some cheap ebay wrenches to try, but really need time to even open my box they came in. Seems to just not be enough hours in the day and going to work and coming home from work in the dark sucks the drive out of a person.
by firefox2501 » Mon Dec 02, 2013 1:02 pm
Good info - thanks Erik, Mike and James!
firefox2501
by Moots1288 » Mon Dec 02, 2013 1:15 pm
HARDTRAILZ wrote:So measure from outside of collar to outside of collar.
I feel you on that!
Been thinking about adjusting mine higher but work is wearing me out. This a good thread with good info.
Good job guys
by Trail X » Mon Dec 02, 2013 1:30 pm
Once we get some measurements, we should be able to create a graph to show the general relationship between lift and preload adjustment.
by mikekey » Mon Dec 02, 2013 4:43 pm
Alright, I finished mine this afternoon. Got impatient. Still gotta go back and do my ball joints SOON.
When I started my center hub to fender was 25 inches both sides. This is with the BDS 2.5 lift on stock springs with just radiator skid and oil pan skid.
I adjusted my Radflo's to 3.75inches both. And then installed, my resting height from center of hub to fender is now 27 inches. My rake is gone, car is level, approach angle is a lot better than it was.
My CV doesn't look anymore off than it did originally, but there is a change in angle. It's not binding, spins freely.
Passenger Side CV
Drivers Side CV
Hope this is helpful to someone. :cheers:
by Trail X » Mon Dec 02, 2013 5:42 pm
Mike, what's the amount of suspension compression with the weight of the vehicle? The biggest thing we want to avoid is too much lift, and therefore bouncing off of the top of the shock all the time.
If you can measure your hub to fender distance with a tire off the ground, that would be awesome.
by mikekey » Mon Dec 02, 2013 5:47 pm
JamesDowning wrote:Mike, what's the amount of suspension compression with the weight of the vehicle? The biggest thing we want to avoid is too much lift, and therefore bouncing off of the top of the shock all the time.
How do I measure the first one? I measured already with the weight of the vehicle on the tire for my first measurement. And I just remeasured, I didn't have the tape in the center of the hub so I'm actually at 27 from center of wheel to fender on both sides.
by DirtyBacon04 » Mon Dec 02, 2013 6:19 pm
compare the distance with weight on tire to distance with weight off tire
by mikekey » Mon Dec 02, 2013 7:35 pm
Ok, I've measured incorrectly several times today. Guess since I was trying to hold it myself and pushing it back towards the fender. Danee helped me tonight and now I have new measurements. At rest in the drive way: 26 1/2 inches. With full drop is about 27 1/2. Hmmmm....
This might mean that my original height was closer to 24 since I've been an inch off each measurement.
by Trail X » Mon Dec 02, 2013 10:15 pm
So you have one inch of downward suspension travel. That's probably just about optimal. I wouldn't want much less than that, or you'll top out on every rise.
by ErikSS » Mon Dec 02, 2013 11:22 pm
I checked today, I have about 1 1/4" of downward travel.
by mikekey » Tue Dec 03, 2013 1:19 pm
Erik how are you higher in adjustment with more downward travel?
by Trail X » Tue Dec 03, 2013 1:51 pm
Doesn't make sense unless the lower shock bushing is shot on his, or something else is limiting your downward articulation Mike.
by Wahugg » Tue Dec 03, 2013 2:04 pm
Sway bars? However I don't think they would limit the downward articulation if both wheels were off the ground.
-Wahugg
Wahugg
by mikekey » Tue Dec 03, 2013 2:08 pm
Oh good point, I do have my front sway bar connected. All over the road on the Nitto's in the rain without it.
by ErikSS » Tue Dec 03, 2013 3:42 pm
I measured from the ground not the center of the hub. I attempted to leave just enough weight on it to account for the tire. Maybe I missed a little. Dunno. I do have some washers in my sway bar. Seems like that could play a factor also.
