Skyjacker C40R is anyone using them
by boda883 » Tue Oct 23, 2012 11:48 am
I see that some people are using the c25r spings but is anyone using the c40r springs from skyjacker. They say they lift 4" to 6". Is there anything out there to level out the front as far as spring or lift kit. Or just strut lifts is our pnly option now.
Front:Rough Country 2" spacer, Moog 81114 & Rear:Z71 springs, Rancho 9000XL shocks
265/75R16 Kanati Mud Hogs M/T, 1.5" spacers
Optima Red Top, K&N Filter
boda883
by fishsticks » Tue Oct 23, 2012 11:58 am
You'd be looking at close to 7" of rear lift with those on our rigs.
by boog2006 » Tue Oct 23, 2012 12:02 pm
fishsticks wrote:You'd be looking at close to 7" of rear lift with those on our rigs.
That would be awesome....if the front could keep up :(
Boog2006 Build Thread
boog2006
by boda883 » Tue Oct 23, 2012 12:56 pm
How much lift does the C25R give. I thought it was suppose to give 2.5.
boda883
by The Roadie » Tue Oct 23, 2012 1:08 pm
4-6" lift on Tahoe. More on our platform. We can't USE 7" on our platform. Stuff limits it. Shocks, brake lines, ebrake lines. Difficult stuff to modify.
by Moots1288 » Tue Oct 23, 2012 1:10 pm
Brake lines defiantly difficult I've been trying to find fittings for braided hose lines that'll give our platform 6 inches of droop with the brakes but no adapters are made to go to 1/2-20 female. It's a pain!
by HARDTRAILZ » Tue Oct 23, 2012 2:14 pm
boda883 wrote:I see that some people are using the c25r spings but is anyone using the c40r springs from skyjacker. They say they lift 4" to 6". Is there anything out there to level out the front as far as spring or lift kit. Or just strut lifts is our pnly option now.
I got the 25's in with 88 springs and Marks 3 inch front spacer lift and the rear is 1 inch taller. SO the 40s would be ridiculous.
There are front spring options if you research, but not much more than an extra inch or so.
boda883 wrote:How much lift does the C25R give. I thought it was suppose to give 2.5.
2.5 on a Tahoe but about 4.5 on our trucks.
Moots1288 wrote:Brake lines defiantly difficult I've been trying to find fittings for braided hose lines that'll give our platform 6 inches of droop with the brakes but no adapters are made to go to 1/2-20 female. It's a pain!
Keep me in the loop on these.
by v7guy » Tue Oct 23, 2012 3:24 pm
Matt and I have been talking about the adapters for awhile. I'm pretty confident that there'll be a solution sometime this winter.
by Moots1288 » Tue Oct 23, 2012 3:30 pm
I will, I am calling one place probably today or tomorrow depends on how busy I am at work
by Opeth » Tue Oct 23, 2012 5:31 pm
Your welcome to see how high mine sits any time, and might be able to help you decide how much lift you actually want to run. Seeing one in person actually gives you a better feel of where you want to be at. I'm only going to add a 2" body lift and call it quits there, then adjust my front springs after the weight of Barton's front bumper when I order one at tax return time.
by v7guy » Tue Oct 23, 2012 5:44 pm
Cody brings up a valid point. It's pretty surprising to see how big these things are when they're right in front of you. If you have one local it would help.
