You may not want to go any farther then this. 2" is about the limit without changing other vital parts.Jblazin82 wrote:Is 2in longer enought for marks lift and z71 springs?
Jblazin82 wrote:Marks rear lift is 2" plus z71 is 1.5. Are the bds 2" lift shock long enough for this combo.
That is, pretty much, the standard set-up with many members.bgwolfpack wrote:You may not want to go any farther then this. 2" is about the limit without changing other vital parts.Jblazin82 wrote:Is 2in longer enought for marks lift and z71 springs?
DirtyBacon04 wrote:I'm a fan of BDS's "no fine print warranty". Plus I've been running the BDS for about 7 months now, and I love them.
Skindiggers wrote:I think the BDS option is the best because they fit perfectly and you will not have to use washers and they offer you 2 types of shocks
DirtyBacon04 wrote: I'm a fan of BDS's "no fine print warranty".
bgwolfpack wrote:That is, pretty much, the standard set-up with many members.bgwolfpack wrote:You may not want to go any farther then this. 2" is about the limit without changing other vital parts.
Downward travel needs to limited to some point. If we go beyond this brake lines would need to be changed at the very least.
You might want to loosen/move the brake line clamps. The panhard bar doesn't contribute to limits - it just swings the axle to the right as the suspension extends. Its only purpose is to try to keep the axle centered left-right.Beamer wrote:Does the panhard bar limit the downward travel before the shock do?
The Roadie wrote:You might want to loosen/move the brake line clamps. The panhard bar doesn't contribute to limits - it just swings the axle to the right as the suspension extends. Its only purpose is to try to keep the axle centered left-right.Beamer wrote:Does the panhard bar limit the downward travel before the shock do?
HARDTRAILZ wrote:DirtyBacon04 wrote: I'm a fan of BDS's "no fine print warranty".
Except it does not apply to shocks even if they rust or leak...
NC_IslandRunner wrote:It's in the non-existent fine print...........
