Thanks,
Ryan
TransAm-98 wrote: Price would be $200 a pair, or $350 for a complete set.
bartonmd wrote:TransAm-98 wrote: Price would be $200 a pair, or $350 for a complete set.
I was feeling bad about charging $100/pair...![]()
TransAm-98 wrote:Sorry about the price, my coworker just asked me to put it out there for you guys. Cost in materials alone for a full set is over $200 for us. I'll let him know the price is a little steep and see what he says. It's his shop so he makes the call.
TransAm-98 wrote:I posted a list of the parts that we used in the smaax thread awhile back. You can look it up and do the math to see what price the parts come out to. There are cheaper alternatives obviously, like a set of Smaax for $100 less. Or we could could have found some tube and welded nuts to the end, or gone even cheaper and just threaded a male heim joint into a female heim joint and called it a day. Instead we used quality parts, nice tube adapters with a lot more thread to support a lot more weight, threaded accordingly so that you can adjust the end link on the car without unbolting one side of it. I believe it to be a very solid piece with little chance of breaking or wearing out. I know a lot of people ride around with no swaybar and I did too for awhile. I didn't put them pack on until we made these and I have to say that it feels 100x better since I did. Especially driving through mountain roads with my GF up front + gear and 2 large dogs in the back. We didn't mean to offend anyone with the price, but if you want to look up the cost of materials you can see where it comes from. I'm still working on making quick disconnect version that I would feel confident putting my name on. I suppose we can try this again once I've ironed out the kinks in that.
bartonmd wrote:By the nature of heim joints, they're stronger than ball joints, but they don't last as long, because they get crap in them that eats them up... The good thing is that 1/2" heims are $7 each, and the other parts are what makes them special...
Skidder wrote:bartonmd wrote:By the nature of heim joints, they're stronger than ball joints, but they don't last as long, because they get crap in them that eats them up... The good thing is that 1/2" heims are $7 each, and the other parts are what makes them special...
Mike/Ryan, (it was Mike's quote/but Ryan is Dr. Frankenstein in this thread) Just want to be sure I interpreted this comment correctly. It seemed to me that you mean, "Instead of 100 bucks per pair (SMaxx) that you will have to replace every year (just a WAG), Ryan's would be a larger up front cost, with 7 buck replacement cost for each heim joint failure every year (again, just a WAG)".
So basically over a two year period, new SMaxx every year = 400 bucks. Ryans...350 bucks up front + 56 bucks for all new heim joints for second year (which is not likely?) = 406 bucks. Third year, SMaxx total = 600 bucks. Ryans total = 462 bucks...
Sounds like this option gets less expensive over the years, because the base parts are not "fire and forget". So, if you look at this like a chess player (more than one move at a time), instead of a checker player (no thought beyond the next move), this option may not be a bad as the shock value of the initial cost.
Not really realevant, but I really like the looks of these. If they were painted with zinc chromate, they would look just like the control linkages on every helicopter I've flown for the last 20+ years in the military. Ha.
bartonmd wrote:I understand that was directed at me, but if it's strong enough, why not? There doesn't seem to be a need to use the "high strength" heims or over-sized tube for this...
Heims, greasable: 4444T301 - $7.05 each = $28.20/pair
tube-end welded nuts: 94640A160 - $5.14 each = $20.56/pair
7/8 I.D tube: 89955K95 - $64/6ft = ~$11/pair
Grade 8 bolts - $2 each = $8/pair
Interference-threaded nuts I told you to use in the first place - $1/each = $4/pair
Lug nuts you should be using - $2 each = $8/pair
Total parts cost per pair - ~$80... $55 if you just weld nuts onto 1/2" I.D. DOM tube...
Further, you used 1/2 of my design (which I gave you in the SMAXX thread), but you should have used all of it... Your bottom mount will not work... It's doing exactly the same thing as somebody putting the nut halfway onto a stock end link... It's going to rock back and forth in the hole in the control arm, and wollow the hole out to the point of not being useable. I also told you this in the SMAXX thread. Also, your top bolt isn't deep enough, and isn't into the interference-threaded part of the nut...
If somebody wants to make their own wrench-disconnectable, long lasting, dirt-resistant adjustable links with no welding, they can just get some of these (below) and some threaded rod...
6058K39 for $10 each, or $40/set
ETA: Or like you said above, if somebody wants to make their own QD links with no welding, they can use my design for the bolts (again, spoon-fed in the SMAXX thread), and use a pair of the female links and some threaded rod... Those break out like:
4444T231 - $6.98 each = $28/pair
So $48 for something more than as strong as it needs to be, that doesn't require a welder... Just a drill press, or a hand drill and a vice...
TransAm-98 wrote:bartonmd wrote:I understand that was directed at me, but if it's strong enough, why not? There doesn't seem to be a need to use the "high strength" heims or over-sized tube for this...
Correct Barton, I did use what the advice you offered me on disconnects as you were also telling me to produce these. I used your idea on the quick disconnects on my car but as I said earlier I'm not selling quick disconnects as I'd like to have more testing done before marketing a product like that. I've been running the fixed version of these on my car since July and there has been zero wear on hardware or joints. While it is true the heim joints will allow some debris in there and may wear over time, how much rotational movement is being put on that ball that it's going to get worn out to the point of being useless and overly noisy in a swaybar application. The only reason that the stock links fail is that they are not long enough to handle the extra strain that the lift puts on them. The Smaax links wear prematurely because of a poor design that still cost you over $200 and will have to be replaced as they can't handle the abuse. As said before, this was only a feeler thread and I will absolutely take all advice/criticism and do what I can with it. This whole idea was just because I thought some of you might be interested in this product. For a market that we don't necessarily specialize in. It's really only us trying to help you guys out a bit with something we came up with. I originally posted up the link and parts list we used so you guys can do it yourself. Only after being asked to produce these did we offer to sell them. We specialize in GM cars and I offer any advice I can when we happen to have time to play with this platform, which is time we rarely have. Such as in the Treadwright thread where I told you how we tried to fix the speedo calibration and failed, then how I recently posted again on a fix for the pre 06' cars. Thanks for "spoonfeeding" me the info on disconnects Barton. I used it and am trying to better the design and am in no way shape or form taking credit for it, or selling it for that matter. We are accustomed to building cars and products for people that have a demand for product/car that will handle extreme abuse and not have to come back to us after every race for repairs or rebuilds. We used high quality products to make this part which is why the price is high on them. It would seem that the price of these has upset a few of you and I apologize for that. But we're not a fan of cutting corners, especially when the only marketed product out there right now is one that doesn't hold up. Good luck to the many other fabricators on this forum on coming up with a better and cheaper product. Competition drives innovation, and so far this thread has been pretty enlightening in that matter. So I suppose it's time for us to hit up the ol' drawing board again.
