offroadTB.com • View topic - Shock choice question
by ScarabEpic22 » Tue Aug 16, 2011 3:16 am
This is my first thread over on the lifted side of the world, decided having my 02 SWB TB at stock height wasn't cutting it for me. Now that I have the SS, no need to go low, so I went high! Just got one of Mark's new 3" lifts, already have the front end ripped apart thanks to my dad and brother helping out. Both strut assemblies disassembled (didn't have to cut the shocks this time) and the UCAs flipped in about 3 hours, not too shabby in my book.
So my dilemma is shocks, I have Bilstein HDs all around now and after being dropped 2" for ~60k then being at stock height for the last 5k, they're ok but on their way out. I'd rather replace everything now and not tear the front strut apart again in 6 months.
Quick rundown of my 02 from what Ive read on here and seen on the truck:
02 SWB 3.73s + G80
Dark blue front springs (think they're 87s, pretty good I guess. My RPO codes dont match the sheet on here though, I have 6SK, 65I, 652, 7SJ, 8EX, and 9EW. Think one of the 6s and the 7 denote front springs...) [EDIT: They're not 87s, no SWB trucks came with them]
Regular rear springs? (haven't seen anything on them being special, imagine there's something that Im missing here)
3" front lift
2" rear lift
Going to run a set of Bridgestone Dueler A/T Revo 2 255/65R17s on some LTZ rims Ive been running as a winter tire setup on my SS (commence joking about almost stock tire size here).
Going to keep all the stock springs for the time being, mostly doing the lift for my brother to take the TB back to school in Montana with him where there's snow on the ground for 5-6 months. Thinking Skyjacker N8030s for the rear and another set of Bilstein HDs for the front. Apparently Bilstein has changed their part numbers, believe I should be looking for 24-103336 now instead of F4-BE5-A333-H0.
Other options are Pro Comp Toxic 415509 (or other Pro Comp that works for a 2" rear lift).
Any suggestions/comments? This is a light duty offroad rig, mostly I want a set of shocks that 1) I can get locally [can do for the Skyjackers, Pro Comps, and Bilstein HDs] and 2) ride pretty well on the highway.
Thanks guys, appreciate any and all insight!
Erik
ScarabEpic22
by Trail X » Tue Aug 16, 2011 8:39 am
You have an 83 and an 84 spring. Not 87, I don't know of any that came stock with 87s.
by navigator » Tue Aug 16, 2011 9:39 am
I know Mark suggests the skyjacker H7030 as an affordable option for the rear. I seem to recall the N8030 as an upgraded version.
Keep in mind that you'll have to get some grade 8 washers to fill in the gap between the shock and shock mount for those.
You could also go the BDS route, they don't require the washers. For more info on them you can search this thread that I have bookmarked.
viewtopic.php?f=15&t=260&start=20
by ScarabEpic22 » Tue Aug 16, 2011 11:50 am
ScarabEpic22
by Trail X » Tue Aug 16, 2011 12:09 pm
by djthumper » Tue Aug 16, 2011 2:09 pm
by ScarabEpic22 » Tue Aug 16, 2011 2:41 pm
ScarabEpic22
by navigator » Tue Aug 16, 2011 2:50 pm
I'm running stock shocks in the rear with the Z71 springs which are about 1.5 inches of lift, not quite as tall as Mark's lift. The ride is great on the highway, bumps and all.
I have not ridden them offroad yet though so I can't comment on that.
From reading responses previously I think a lot of folks have ridden with the stockers for a little while but I think all have upgraded before too long. Most folks likely beat on their rigs more than I do though.
by ScarabEpic22 » Tue Aug 16, 2011 3:06 pm
ScarabEpic22
by navigator » Tue Aug 16, 2011 3:17 pm
give it a little time for others to chime in before you place your order.
Here are some comments to a similar post I had a while back.
I wanted to run the 3/4 spacer and the 1.5 lift springs which would put me at about 2.25.
Depending on the situation the 2 inches might top out your rear shock and ride rough on bumps.
Mine do fine with the 1.5 springs but I can't speak for certain on the 2 inch spacer.
viewtopic.php?f=15&t=2037
by ScarabEpic22 » Tue Aug 16, 2011 3:37 pm
Thanks for the link Chris, Ill see how the ride is but unfortunately its either wait until October to install them or use some generic Monroe shock (stock height) so Id rather be in for a crappy ride for a bit then use the right shocks for a lift. 2" will put me at the very top end of the shocks I know, hope its bearable.
ScarabEpic22
by djthumper » Tue Aug 16, 2011 3:44 pm
I considered the H7030 but considering some of the washboard trails I take I knew the gas filled shocks would do much better. They are the same length anyhow.
Depending on what you are already running up front I would think those would hold out until October. If the rear is already going to be pushing it, length wise, I would get those replaced.
by Trail X » Tue Aug 16, 2011 3:45 pm
by ScarabEpic22 » Wed Aug 17, 2011 11:15 am
ScarabEpic22
by Trail X » Wed Aug 17, 2011 11:23 am
The rpo list in the other thread is not complete. I began it, thinking it would cover all years, but then realized the list was far longer than I imagined.
by ScarabEpic22 » Wed Aug 17, 2011 11:47 am
ScarabEpic22
by Nakashige » Wed Aug 17, 2011 11:51 am
i am running the n8030s as well check out my build thread
Nakashige
Vendor
by ScarabEpic22 » Fri Aug 19, 2011 5:41 pm
ScarabEpic22
by Nakashige » Fri Aug 19, 2011 11:31 pm
Personally I like them rides a little rough but I dont mind it
Nakashige
Vendor
by ScarabEpic22 » Sat Aug 20, 2011 3:35 pm
ScarabEpic22
