by Trail X » Mon Feb 14, 2011 11:25 am
Smells like an appearance mod, unless you desert race - there's really no need for dual shocks.
Either way, good luck creating something that will hold up to the forces. You'll notice all of the lift blocks are done at the top side of the strut. This is because it simplifies the applied forces into compression-only forces (essentially).
If you add some contraption on the lower-mount to fit a Tacoma strut, you'll be dealing with compression and bending loads. One of our members broke a custom adapted tacoma coilover because these bending loads were not taken into account by the company that adapted it.
The truth is, we can easily max out our front suspension with simple lift blocks and stiffer springs. So instead of focusing on the shocks and springs, take a look at the other challenges (such as the location of the differential) first. Focus your efforts on finding a double-CV, high angle front halfshaft for us, that'd be a bigger benefit for everyone and it would allow you to lift beyond the standard limits.
