offroadTB.com • View topic - another body lift/steering extension question
by 06blazin » Fri Jan 14, 2011 5:31 am
so i know how hard and almost impossible it is to come across them for body lifts. but i was looking and something came to my attention, i tried search but didn't get far so here it is.......
i guess you can't get the extensions separate from zone and i know markmc can't really do them anymore either. however i noticed that zone does sell one for the s10 separate! my question is, is this something that can work instead of trying to fab one yourself? pictures or hard to tell but look similar.
normal extension
s10 extension (sorry terrible pic but hard to find good one)
06-TB: G80, Liftmiester, Z71, H3's, 33"'s, BDS, Bilstien, Gibson, Adj panhard + more
06blazin
by MrSmithsTB » Fri Jan 14, 2011 11:03 am
It is possible, but you can't tell based on pics alone. Looks similar to the one I made for temporary use, as it would slide inside the shaft and not over. If you do a little more research and find out the s10 dimensions, I'm sure you will find your answer.
On a side note.... I don't know if this is safe or if it applies to everyone, but I found it to be true with my vehicle. When I took the body lift off and moved the steering shaft back down to the rack, I was able to fully insert it and reinstall the bolt. Made me wonder if it is even necessary to use an extension with a 2" lift. I had no issues turning the wheel. If anyone tries this, it was not my idea. I don't want to be blamed for anything broken or anyone harmed. Looked to me that there was enough forgiveness in the shaft to get away with it.
by janesy86 » Fri Jan 14, 2011 11:18 am
How much is just the steering extension? May be worth it to just try and see if it works?
But Bot, that is interesting about maybe not having to use the extension. Body lifts could be done on the cheap (homemade) if so.
I realy want the extra wheel well room but don't want to deal with the hassel right now of relocating my bumper and sliders.
by 06blazin » Fri Jan 14, 2011 1:59 pm
the extension is only like 20 bucks from zone. i talked to mark and he said it most likely wouildn work as our steering shafts are an oddbll size but still wondering if could be modified a little.
and on the option of not using the extension..... i know not the same but my 01 zr2 blazer had a body lift with no steering extension and work out fine. but whether or not the TB will be ok im not sure
06blazin
by MrSmithsTB » Wed Apr 06, 2011 7:26 pm
by chevycrew » Wed Apr 06, 2011 10:17 pm
I asked Zone when I wanted to do a 2", they said they would sell me just the extension...
When I cut out the front end, Ill pull apart the shaft to see how much is really inside. Then we will all know for sure.
I didnt use one on my 1" lift...
by dirty anton » Wed Apr 06, 2011 11:07 pm
the steering may get a little tight with no extension with 2 inch blocks. i wish i could have gotten a 3 inch split type movable steering extension for the 3 inch body lift. because of the increased angle of the shaft the steering got a lot tighter for a while with the 2 inch steering extension.but before with it on the 2 inch body lift the steering felt ok though.
dirty anton
by MrSmithsTB » Wed Apr 06, 2011 11:15 pm
Zone told me it was available as part of the kit only, but that was months ago. Perhaps things have changed. I would love to get just the extension so I can just do the 3" and be done with it. I would just hate to buy an entire kit when all I am going to need are the blocks/bolts and steering extension. And I do not feel like making another version of my redneck extension like I did before.
Anyone wishing to go a little more permanent with the mod could always buy the 17mm DD blank shaft, cut it to size and drill it, and then weld it to the existing shaft.
by chevycrew » Wed Apr 06, 2011 11:27 pm
ok ok so it wasnt zone i asked...
It was high-voltage.
I had to look back in my pm's sorry for the confusion.
by 06blazin » Thu Apr 07, 2011 12:18 am
06blazin
by MrSmithsTB » Thu Apr 07, 2011 7:35 am
From what I understand, voltage is still searching for a reliable source to produce the rear bumper relocation brackets and the steering extensions. I've found a way around the rear bumper relocation. As long as there is enough slip in the steering shaft, the 2" body lift will be getting a lot less expensive.
