stock suspension and tire size (245/65/17) with 16mpg???????
by v7guy » Fri May 25, 2012 6:48 am
A lot of these electric fuel pumps use the fuel to help keep em cool. Running it that low can have a pretty negative effect on the life of the pump. Not to mention a fair amount of sediment builds up in the tank over the years and you risk sucking that up into the lines and clogging the fuel filter.
by chevycrew » Fri May 25, 2012 7:06 am
I have yet to see a fuel injected rig with a large amount of sediment in the tank, its usually a very small amount. The pump sucks from right off the tank floor, so the fuel level should not affect sediment being sucked into the sock.
by Trail X » Fri May 25, 2012 11:25 am
Blazintrails03 wrote:How much do you guys normally fill up with?
18-20 range normally.
by navigator » Fri May 25, 2012 11:46 am
It is a good practice to always have at least 1/4 tank or more, you never know when an emergency will come up and a 1/4 tank will get you most places.
by dvanbramer88 » Fri May 25, 2012 1:22 pm
v7guy wrote: Not to mention a fair amount of sediment builds up in the tank over the years and you risk sucking that up into the lines and clogging the fuel filter.
BS. That is the biggest wives tale ever. Simply just doesn't happen on a fuel injected engine. I was in my 15 year old gas tank last year to change the fuel pump, NOT a speck of debris or sediment. It was perfectly clean in there. Also, the filter sock was perfectly clean as well.
