dvanbramer88 wrote:Thanks...
Looks like it was Mikekey and he edited the post. That's what Erik was getting at though.
HARDTRAILZ wrote:dvanbramer88 wrote:Thanks...
I guess since I been texting Erik this morning, I will ask him cause I really doubt you can read his mind.
dvanbramer88 wrote:Sure, let me know.
HARDTRAILZ wrote:dvanbramer88 wrote:Sure, let me know.
He was just cracking on Mikekey before you tossed your two cents in.
Maybe now that this thread has been pushed to another page all the real info I asked about will be lost. Glad you helped after Mikekey had already answered my question.
dvanbramer88 wrote:Somebody said "Mike and Matt both had bumpers" or something along those lines. I can't find it but I remember reading it this morning.
Anyway, I also thought to myself, wait, moots doesn't have a front bumper. But it is possible that that person meant Regulator also.
I think that is what Erik is getting at.
HARDTRAILZ wrote:Is everyone getting same 600 rate springs?
What length? I know Barton got half inch over stock?
Barton and previous threads on radglo said 2.5 inch shock but Johnny's site says 2. Which is it?
Are there options or are these all being built the same?
Is silver the only color for coils or are there other powder coat available?
Please correct if wrong but color is silver or chrome.
They are 2 and 2.5 was mentioned as comparison in previous threads.
All 3 sets currently are built the same length and spring rate?
No one has tried a spring closer to 88/89s with 450/500 rate?
Mentions of an inch longer being possible were made but never confirmed?
Could their be an advantage to a 500 spring and extra length if going to up.near the 4 inch lift mark like I currently sit?
Or could a 650 rate be better with full bumper, tube brush guard, skids, winch?
So far two people in this group buy I heard from are just going with what was built previously. Worriesme that when reading how the length and rate was chosen had so little reported research, there may be even better or more performance to be gained with some tweaking.
HARDTRAILZ wrote:Please correct if wrong but color is silver or chrome.
SO far yes. I'm sure RadFlo can put a different coil on if you prefer. This is the coil they chose when I sent in my stock strut assembly, and they looked up the factory Specs. How exactly they chose it I'm not sure. They are the coilover specialist
We made the top plate a half inch thicker for Mike's. Effectively the same as a 1/2 top spacer to a Bilstein HD. It worked very well for him, so we kept that measurement.
Radflo said due to size and space of this front suspension the 2" shock diameter will fit and perform better. The coil says 2.5" on it, so that might be where mike got the 2.5 from.
What options do you want? If the shock travel is any longer, it will be wasted, as the CV's and control arms can only travel so much. Do you have a specific option you looking for, or just options?
Silver is the only option right now, they come that way from Eibach
Yes
No one yet. So far we know what RadFlo put together works, I'm sure a lighter spring, or a heavier spring will work too. But obviously no one has tested that.
I sell the exact same coilovers for a standard cab Tacoma as we do for a double cab long bed. Do they ride a little firmer on the standard Cab vs. the other, of course. But they are still way better than stock suspension.
If you have an overall length you want the shock, I can have them account for that. The top plate can be built thicker. But I'm assuming since I got their pricing down as low as they could go, it may cost a little extra for the material.
Sure, could be, I don't know. Depends on what you consider an advantage. Usually a softer spring has to be longer to get the same lift height. When you put a longer spring, which has more wraps, on a shock with a given length you can run into Coil binding issues when under full compression. Basically your coil can compress all the way, stopping the travel before the bumpstop does.
I think my SAW's with 650s are way too stiff, and I have a full 3/16' plate bumper. But ultimately "ride firmness" is real subjective, and changes from one person to the next. Some guys really like a firm ride, some guys like the softer, floating ride.
