offroadTB.com • View topic - Rear Panhard Bar Discussion
by bgwolfpack » Wed Nov 11, 2009 5:50 pm
001211TS07-107.gif I need to be clear here.
#12 is 32 1/4"
#14 is 38 5/8"
Center to center of bolts.
by bartonmd » Wed Nov 11, 2009 5:57 pm
by bgwolfpack » Wed Nov 11, 2009 6:04 pm
Correct, my post within the Quote didn't post right. I was scrambling to make sure you got the right info. Sorry for the delay.
by MrSmithsTB » Wed Nov 11, 2009 8:34 pm
At risk of sounding redundant. If dropping in raising only could inhibit more than help, why not fabricate extensions on each side to cut the local deviation in half while maintaining the overall accommodation? Obviously, you would need to be pretty complete as far as you suspension setup, because nobody wants new extension s every time they add or remove something, but it could work. Keep the bar in it's stock location(respectively), avoid clearance issues, and gain stability. I notice the side hop hitting bump during turns on paved roads and I don't like it at all.
by foosh » Wed Nov 11, 2009 10:15 pm
Looking at it, its probably more worth it to just buy the 100 dollar adjustable bar from suicide doors...
foosh
by Trail X » Thu Nov 12, 2009 1:15 am
The adjustable bar doesn't help side-hop, only helps with the offset appearance of the rear axle.
by foosh » Thu Nov 12, 2009 2:05 am
Are you talking about axle hop or body hop, because panhard bars are made to prevent axle hop and the right panhard bar will reduce it more than one that's the wrong size for the suspension... so in theory the bar will help slightly. I mean i may be wrong, this is just my understanding of it from a little reading and experience.
foosh
by Excell » Thu Nov 12, 2009 9:38 am
Excell
by Excell » Thu Nov 12, 2009 10:22 am
While we're discussing this, has anyone measured a stock truck to see if the diff is dead centered, or if GM set a little off?
Excell
by foosh » Thu Nov 12, 2009 4:43 pm
foosh
by Excell » Thu Nov 12, 2009 6:01 pm
Excell
