fishsticks wrote:That crossmember doesn't do too much. The ridigity back there comes from the rear bumper itself.
Still, I wonder what prompted the change in design, I remember only having to corner cut a couple inches back.
Correct, The top edge of the crossmember is pretty much useless.. the bumper is what gives rigidity in that area..
The new brackets have a bolt that transitions the vertical surface of the crossmember to the frame..realy not needed, but i added
them anyway..
Change was made due to complaints and confusion from guys when they do the install..
Feeding the bolts with fish wire, relocating the trailer plug and cutting the original bumper brackets to fit
by the customer meant several phone calls to explain.
Not that i mind talking someone through a install (do it all the time. try calling customer service at the other lift companys on a weekend..lol)
but when its the same question over and over, tells me the design needs adjusted and simplified..
The new design utilizes 2 of the original bumper weld nuts each side (not just one) making return to stock more easy and gives more strength.
No more blind bolts (PIA) to pull with fish wire through bumper tube.
No cutting and relocation of trailer light plug.
Wanna go back to stock? 4 bolts each side...Boom..your done..
