Moots1288 wrote:He's is like the marks 2.5 style using the stock strut mount
Tenny wrote:Moots1288 wrote:He's is like the marks 2.5 style using the stock strut mount
YES....exactly like marks 2.5 kit
only the spring spacer is slightly larger in width.
the strut spacer (on top) is 1/2in wide.
I like marks 2.5 kit
I DO NOT like the 3in
ErikSS wrote:I just looked over the Supreme Ebay add. I'm not convinced I know why Tenny bought it. Free can opener and sticker with every purchase!!!
DirtyBacon04 wrote:My curiosity is how is one polyurethane stronger than another? Or are you using a different material for your bushing? The error with BDS bushings was the top washer being to small in diameter and the constant force of full extension eventually will tear into the poly. Then the middle bushing will wear; then the center sleeve will get eaten through by the threads of the shock; once there's no more sleeve, it's into the upper strut mount. I thought we had solved the problem with BDS (in theory) byusing a a bigger top washer...
yup.. They were mine and I had them in my truck 2 weeks until I got my radflos, and he had it in his truck a month and hasn't even driven it everyday.HARDTRAILZ wrote:I seen it...month old n failed.
JamesDowning wrote:Donny, I thought it was your lift block that cracked out and had to be re welded? Maybe it was another.
The Roadie wrote:OEM rubber mounts have been proven to be not bulletproof when wheeled hard. Claims from folks who haven't wheeled them hard are just not qualified claims. Sorry. Spacer robustness isn't sufficient.
Tenny wrote:just wonrdering where anybody said such a thing..???
as far as a SOLID spacers in a lift kit..??? BULLET PROOF
just saying
Tenny wrote:
weary of what...???
the kit is all SOILD machined aluminum pieces front and rear.
I don't EVER seeing this product failing, from what I see its indestructible
http://www.ebay.com/itm/Chevy-Trailblaz ... 1219425234
Tenny wrote:I hope you don't mind me being blunt with you....
YOUR KIT FAILED, BECAUSE HE USED A CHEAP BUSHING......
MY kit are SOILD pieces, and are simply indestructible....period
The Roadie wrote:Please post a pic of the upper shock mount on your design. Would love to understand how we can modify ours to be bulletproof.
Tenny wrote:The Roadie wrote:Waiting for the upper mount pics.
I used factory mounts, what don't you understand...???
mikekey wrote:So nice job back peddling there. You get a gold star.
