fishsticks wrote:I wondered this too when I got mine...couldn't find a definitive answer.
I ended up with this.
Ring - Washer - Washer - Shock Bushing - Washer - Ring
...on the tube.
Zero problems so far.
The Roadie wrote:If you didn't get the right hardware, the BDS guy is a vendor/member here and I'm SURE will make it right ASAP. We're much more open to vendors for functional offreaders than the greedy OS.
Zero wrote:Please correct me if I am wrong, but isnt this guy installing a set of 5500 series BDS shocks? if so, then you are wrong. The BDS stuff is made for our trucks. Even specifically valved for our trucks. Unless I overlooked a post that stated he was using a random set of 5500.
aaronrules wrote:Got it installed. Didn't use any washer on the top mount, just squeezed the mount basically onto the shock. And on the bottom I did all three washers and the two bushings. Drove it about 30 miles and don't see any apparent damage or moving...I would just feel better if there were washers for the top mount next to the bushings, and one more on the bottom like the roadie's...I might let it eat this way...but the PM is going to be sent to BDS rep right after I post this, just to see what the deal is.
BDS Suspension wrote:aaronrules wrote:Got it installed. Didn't use any washer on the top mount, just squeezed the mount basically onto the shock. And on the bottom I did all three washers and the two bushings. Drove it about 30 miles and don't see any apparent damage or moving...I would just feel better if there were washers for the top mount next to the bushings, and one more on the bottom like the roadie's...I might let it eat this way...but the PM is going to be sent to BDS rep right after I post this, just to see what the deal is.
You have it on there right. When we made some changes late last year to these shocks we also changed the bushings that are supplied. The current urethane bushings are physically wider then the bushings we used to supply with the shocks a year or so ago. The new bushing don't require spacer washers at the top mount and only require 3 at the bottom. Those of you that only receive 3 washers have the new, wider bushing. Nothing wrong with the old way, just a couple less washers are necessary.
Just to review, the lower mounting configuration is washer, spacer, washer, bushing, washer, spacer....Or spacer, washer, washer, bushing, washer, spacer. Either one works, all that matters is all the parts are in there and there are washers on each side of the bushing.
Hopefully that clears it up guys, let me know if you have more questions.
Matt
BDS
bgwolfpack wrote:
Let me make this clear, I will be buying a set of BDS shocks. I have no problem with them. Only that we install them and see the little problems and talk about it. They just send them out and call it good. It up to us to install them properly and make sure we use the correct parts to do so even if they (BDS) doesn't send them to us.
