all of these abbreviations are confusing...help!!
by blackshirt402 » Sat Dec 25, 2010 7:18 pm
im new to the forum, andive been reading on a few posts. what ive read made sence for the most part but abbreviations like uca and lca and bj are what? any other abbreviations i might need to know as far as suspension goes, please dont be afraid to post on here with there meanings!!
thanks guys!!
blackshirt402
by blackshirt402 » Sat Dec 25, 2010 7:20 pm
and also how would i find out if if i have a g80?
blackshirt402
by blackshirt402 » Sat Dec 25, 2010 7:25 pm
damn i figured it out guys about the uca and lca. upper and lower control arm... right?
blackshirt402
by djthumper » Sat Dec 25, 2010 7:37 pm
could be Upper CAlifornia, Lower CAnada and I will leave BJ up to you...
for the G80 look at the RPO codes in your glove box if you see G80 then you have one if not you don't.
by fishsticks » Sat Dec 25, 2010 7:55 pm
djthumper wrote:could be Upper CAlifornia, Lower CAnada and I will leave BJ up to you...
:slap:
UCA=Upper Control Arm
LCA=Lower Control Arm
BJ=Ball Joint
G80=RPO code for locking rear differential
SAS=Solid Axle Swap
RTFM=Read the //// Manual
LMAO=....
by gotspeed1 » Sun Dec 26, 2010 6:09 pm
Requirements before posting here...
1. An introduction thread...What your truck is/has, what part of Nebraska you're from (I'm assuming you're from the good part judging by your area code), ect.
2. READ, READ, READ!!!
By the way, do you have any places you go off-roading in Nebraska, I'm from Ashland and am home every few months? :flex dirty:
gotspeed1
by Trail X » Mon Dec 27, 2010 10:02 am
Ball joints.
There are two on each steering knuckle - one connecting the UCA and one connecting the LCA.
It sounds like you've done some reading - at least you didn't ask what type of lifts there are.
by The Roadie » Mon Dec 27, 2010 11:46 am
OS = Other Site (trailvoy.com) - Older, larger, but not dedicated to FUNCTIONAL offroading the way we are.
LMFAO = Lifts Meant For Appearance Only - What folks install in the "Suspension" forum of the OS.
