Please don't steal this from me, but...
by aaronrules » Sat Apr 03, 2010 12:23 am
browsing ebay, I came across this auction...what do you guys think?
http://cgi.ebay.com/ebaymotors/Hummer-H ... ccessories
I really like the look H3 wheels on the TB's. I know I would still need the wheel adapters, but anything else to get these to fit?
aaronrules
by Trail X » Sat Apr 03, 2010 12:33 am
Is it really a 5 bolt wheel?... or does the seller not know how to count?
by aaronrules » Sat Apr 03, 2010 12:36 am
okay, what about this one?
http://cgi.ebay.com/ebaymotors/Set-4-NE ... ccessories
I am just wondering if the size of the wheels and tires will require more modifying of my TB or not.
aaronrules
by aaronrules » Sat Apr 03, 2010 12:43 am
I am about to end up asking forgivness instead of permission on some of these. Either the low priced on or the higher...don't know which to go for though. She's gonna be mad!!!
aaronrules
by aaronrules » Sat Apr 03, 2010 12:48 am
Well I bid 500$. If I win she is going to be PISSED!!!! But oh well...she will get even more mad when she finds out I have to get wheel spacers too!
aaronrules
by Gordinho80 » Sat Apr 03, 2010 1:15 am
Not sure how far from Nashville you are... but...
http://nashville.craigslist.org/pts/1671468758.html
by aaronrules » Sat Apr 03, 2010 3:32 am
Well, right now, I am half way around the world. But if I was home, this would be a pretty good deal. I could drive to Nashville in a day from my house.
aaronrules
by aaronrules » Sat Apr 03, 2010 3:34 am
if I accidently end up with these wheels and tires...other than the suspension lift and spacers, will I need to do anything else to get them to fit?
aaronrules
by Philberto » Sat Apr 03, 2010 3:40 am
285 75 16 will require trimming of your wheel well liner, though I don't know how much. Also make sure your spacers go from the tb bolt pattern to the 6x5.5 pattern for the hummer wheels.
Eta: just noticed the second ebay link. See post below
Reason: doh!
by Trail X » Sat Apr 03, 2010 9:47 am
aaronrules wrote:okay, what about this one?
If you weren't in Afghanistan I'd have given you the tools to answer the size thing yourself.
However, the tires are 265/75/16, which equates to a 31.6" diameter. They will probably fit without modification (with wheel spacers), but I don't know the frontspacing of the wheel, so I'm kinda making an educated guess.
by Philberto » Sat Apr 03, 2010 11:04 am
Ah, just saw the second ebay link. I'm running the same size tires, and all I had to do was modify the wheel well liner with a box cutter to be good. Might be a little bit different depending on the backspacing of the h3 wheel but you should be fine.
by aaronrules » Sat Apr 03, 2010 6:01 pm
Thanks for the help guys. I might end up with these wheels and tires. :shock: If so...I will order some 1.5" spacers that markmc pointed me to. I have already cut up on my fenders in the front, so no big deal if I need to do any more...hopefully I will be home in a little over 40 days, and I work on it!!!
aaronrules
