Off-road Tires
by wildtones » Fri Mar 16, 2018 9:21 am
Hi guys! Can you guys recommend a set of off-road tires for my 2007 Chevrolet TrailBlazer LT? I am currently checking out Mickey Thompson Tires' Baja Claw TTC. Any other recommendations?
wildtones
by itsatruck » Sat Mar 17, 2018 1:33 pm
wildtones wrote:Hi guys! Can you guys recommend a set of off-road tires for my 2007 Chevrolet TrailBlazer LT? I am currently checking out Mickey Thompson Tires' Baja Claw TTC. Any other recommendations?
What terrain are you planning on? On stock truck? What size wheels?
Sent from my XT1635-01 using Tapatalk
Instagram: @tb_overland
itsatruck
by Trail X » Tue Mar 20, 2018 8:10 am
Yeah, its a pretty open ended question. There are so many offroad tires. Your budget plays a bigger factor than anything, then your planned terrain.
by SelmaAdam » Tue May 25, 2021 2:54 am
Try BF Goodrich ALL Terrain T/A KO2 265/70 R17 121S
I'll leave you with this;'Keeping the correct air pressure in your tires helps your tires last longer, helps your car handle better and safer, and helps you save money on fuel.'
SelmaAdam
by Panathoo0 » Tue Oct 19, 2021 2:28 am
Hi all, I think that traction is one of the most important criteria when choosing a car or tires, but not always it all depends on the tires, I personally after I bought a tire with a list of off-road utv tires immediately changed my mind about my car and about tires in general! I recommend
Panathoo0
by Davismark » Wed Oct 20, 2021 11:09 pm
Do you often drive off-road? Or do you drive on-road? I am using BFgoodrich all-terrain T/A KO2 tires, it can be used on the road without any problems. If you only use it for off-road driving, I strongly recommend the BFgoodrich mud-terrain T/A KM3, however, it is a bit more expensive. It all depends on your budget and the terrain conditions you are going to. https://tireer.com/top-10-off-road-tires-for-trucks/ Hope this article can help you make the best choice.
Davismark
