http://www.offroadunlimited.com/orustore/pc/viewPrd.asp?idproduct=8975
They have them in 16 x8 and 16 x10 with 4.5 backspacing.
![Image](http://www.offroadunlimited.com/orustore/pc/catalog/PXA8089s.jpg)
Saxis wrote:Only problem is, without offering a 17", the v8 guys are screwed.
foosh wrote:you don't need a x8, x9, 0r x10 to fit 33's unless they're 305/70/17 then you need an 8 inch rim. I have a bunch of friends with jeeps and old Chevy's and they run up to 345's (13.5) on an 8 inch rim one of the reasons companies put those numbers is to cover their asses just in case, also becuase it warrants the purchase of new rims too, which they can typically cash in on. On a daily driver tho you might want to come a bit closer, but for most 33's your stockers are ok.
foosh wrote:Haha exactly, if a tire strectes to fit then obviously a bigger rim is needed. What with do you have for your 305's?
