by The Roadie » Thu Apr 10, 2014 8:55 pm
It's not about size. It's about the mission. Mission dictates everything, including tread style. It also helps you settle on a rim diameter, which drives aspect ratio, which is part of the discussion if your intended mission involves airing down.
Have you researched or articulated your mission yet?
That you're asking about ATs means you're aiming at a different mission than many of us, where MTs are the target tread pattern.
And anything under 1/2" difference in diameter can be ignored because different styles of tire with the same "nominal" size are never going to be exactly that diameter.
