sufireman_1 wrote:I recently put on spacers. Now when I go to remove the stock wheel, I have to whap it with a large rubber mallet to get it off. Does anyone have a solution for this. Last time I changed a flat it was in a field snowing and cold. That's when I'm gonna want the wheel to come off easier! Also, does anyone recommend a good lift better than the one that comes with the tb? Not a shop lift but something I can use out on the road/ off road. Thanks!
Did we not just go over this..HARDTRAILZ wrote:Lil grease on lip is what others did.
Moots1288 wrote:Did we not just go over this..HARDTRAILZ wrote:Lil grease on lip is what others did.
bartonmd wrote:A lot of tight hub-centric (meaning the hub takes the load, not the wheel studs) hubs/wheels are like that. I have to REALLY kick the rear tires on my K2500HD to get them to budge! If it bothers you, take some sandpaper and take some off of the inside of the hub on the wheel. Not a whole lot, like maybe just the wheel clearcoat or so. Just enough so they aren't sticky.
