offroadTB.com • View topic - LT or P
LT or P
by KYTB4x4 » Sun Jan 05, 2014 7:31 pm
Ok. My lift is in and some new BDS shocks too. Mark is shipping my spacers tomorrow. Time for tires. Its a mild build and the vehicle will still be 90% road driven for the time being. I am going with a 265/70/17 General Grabber AT2. But... that tire is offered in a heavier, tougher, snowflake rated model and a lighter 60,000 mile warranty P type. What to do?
KYTB4x4
by Aries » Sun Jan 05, 2014 8:12 pm
Aries
by Wahugg » Sun Jan 05, 2014 8:15 pm
It all depends on you I suppose.
-Do you tow?
-How aggressive is the off roading you do?
-Do you like a stiffer ride or perhaps a little bit of a softer ride?
-Is there a price difference between the two? If so can you justify the extra expense?
-Do you drive in the snow a lot?
Personally I would go with the LT tire because the perks that come with it such as higher psi, higher load rating, more plys (typically), and softer rubber fit my needs so I can justify the extra cost.
Someone else might want a softer ride, spend less money, and have no need to tow or have more plys. Pick what suits your need best.
-Wahugg
Wahugg
by CNCwell » Sun Jan 05, 2014 8:15 pm
Depends on your needs. If you are doing little to no towing and very little off roading the P type are generally a bit cheaper and last longer. You may also want to ensure that you are getting the same tread pattern on both types. Generally the P type have much less aggressive tread. If you tow and plan on hitting trails it's LT all the way.
--Anais Nin
CNCwell
by HARDTRAILZ » Sun Jan 05, 2014 8:27 pm
P is passenger car.
LT is light truck.
I certainly would not consider this platform a car...esp when asking on a site dedicated to offroading them.
by Cable810 » Sun Jan 05, 2014 8:31 pm
by ErikSS » Sun Jan 05, 2014 8:34 pm
The P tires on our trucks are wearing out too quickly at my work. I'm forcing the company to switch to LT tires for anything bigger than a station wagon. (yes, the 72yo millionaire owner of my company drives a 12yo station wagon)
by djthumper » Sun Jan 05, 2014 9:56 pm
LT hands down.
by NC_IslandRunner » Sun Jan 05, 2014 10:22 pm
LT and you will never worry if your tire can handle the load.
by KYTB4x4 » Sun Jan 05, 2014 10:28 pm
Im leaning LT. Looks like the same tread pattern. They are both the Grabber AT2. CNCwell, I thought I would be the first lifted TB in N.Ky but you beat me to it.
KYTB4x4
by HARDTRAILZ » Mon Jan 06, 2014 8:31 am
I am 30 minutes from N KY.
by CNCwell » Mon Jan 06, 2014 8:37 am
--Anais Nin
CNCwell
by bartonmd » Mon Jan 06, 2014 9:17 am
LT, no contest. LT tires have thicker sidewalls and tread carcass, with more plies. This makes them much more resistant to sidewall punctures and such. The first time I went to TECORE with P-rated Destination AT tires, they preformed really well, traction-wise, but I popped one sidewall, and 1 other one was through the cords, but still held air from the rubber on the inside of the plies, and just barely got me home. I've had these 10-ply BFG AT tires off road I don't even know how many times, and the only punctures I've had in them are nails, and 2 of those didn't even go all the way through the carcass, and didn't leak.
by TBYODA » Mon Jan 06, 2014 10:06 am
by ErikSS » Mon Jan 06, 2014 11:47 am
by v7guy » Mon Jan 06, 2014 11:58 am
passenger car tire or light truck tire for an SUV...
by mikekey » Mon Jan 06, 2014 12:00 pm
I actually had General Grabber AT/2's in 245/70/R17 and put a lot of miles on them. You want to make sure they are LT's and they weight about 40lbs each. Great tire, highly recommended by a number of folks here. They perform well in multi-weather conditions, on the highway and offroad.
:thumleft:
by bartonmd » Mon Jan 06, 2014 12:09 pm
by KYTB4x4 » Mon Jan 06, 2014 3:26 pm
Aww come on V7. Cut me some slack. I did preface with 90% road driven. Lol. Ok its settled, Im going LT. And CNC youre right. We do need a KY ride. Im going back to Rock Castle this spring. Its only a couple miles in but was scary as hell rolling stock last year.
KYTB4x4
by CNCwell » Mon Jan 06, 2014 4:14 pm
--Anais Nin
CNCwell
