Tire Time
by 06MidnightBlue » Thu Oct 18, 2012 9:00 pm
Nakashige wrote:Anyone running Toyo Open County MTs
Yes sir
The truck is flexing a wee bit in the pic
06MidnightBlue
by Nakashige » Fri Oct 19, 2012 12:06 am
how do you like them? putting them on the Duramax AT2s are outta stock. Loud Quiet?
Nakashige
Vendor
by 06MidnightBlue » Fri Oct 19, 2012 12:09 am
For a MT, they're perfect. They do howl, A BIT. I have Load E and my TB rides like a Cadillac.
06MidnightBlue
by Nakashige » Fri Oct 19, 2012 12:27 am
I am doing a 295/70/17 on the 2500HD hopefully i can get some decent mileage out of them
Nakashige
Vendor
by 06MidnightBlue » Fri Oct 19, 2012 1:08 am
They have a 60K guarantee
06MidnightBlue
by Nakashige » Fri Oct 19, 2012 1:22 am
Kidding me Right thats great last set of tires I got 25k out of
Nakashige
Vendor
by 06MidnightBlue » Fri Oct 19, 2012 2:04 am
That's just through Les Schwab. I can't speak for other retailers.
I'll post a few pieces of advice that will guide in obtaining the best tire life possible.
The two BIGGEST issues when it comes I get the life out of your tires are AIR CHECKS and ROTATIONS.
Low air pressure causes uneven wear on the inner and outter edges of the tires. Too much air pressure causes accelerated wear in the center of the tread. It's important to find the balance that best suits your particular setup.
When it comes to rotations, each point in your suspension causes the tire at that location to wear a center way due to the geometry of the system itself. Rotating the tires REGULARLY allows them time at each point and betters your chances of even wear.
Another thing to consider in tire life is shock absorber life.
A shock absorber aids in ride comfort and also helps keep your tire firmly planted on the road. When your shock is weak, the spring allows the tire to "bounce" at the will of the road your on. This allows the tire to take on, for a lack of better terms, any shape it pleases. Feathering, cupping, and even separation can be the outcomes of this.
The last thing to consider is alignment.
For some of us, obtaining a perfect alignment is no longer possible because of our lift configurations. However, those with mild lifts can still obtain accurate measurements. When your car is out of alignment, that doesn't mean it will pull to one direction. When there is excessive toe in, the vehicle will not pull, but will quickly wear the outter edge of the tire. So, that being said I would recommend any time you purchase a new set of tires, have the vehicle aligned. It is but a small amount to protect your new investment
This insight is what I have been recommending to my customers for the past 4 years. If anybody ever had any questions, ill be happy to help any way I can.
06MidnightBlue
by Nakashige » Fri Oct 19, 2012 2:35 am
Recommendations for a 3/4 Ton Diesel Towing a lot. on pavement 75 off pavement 25. off pavement Grass Dirt Mud with loaded trailer.
Nakashige
Vendor
by drwfaulk » Fri Oct 19, 2012 8:07 am
Nakashige wrote:Recommendations for a 3/4 Ton Diesel Towing a lot. on pavement 75 off pavement 25. off pavement Grass Dirt Mud with loaded trailer.
06MidnightBlue wrote:Toyo M/T's are working pretty well for me so far. Many of my customers like them too. A lot of guys run them on their 3/4 or 1 tons and can't say anything bad about them
I have a buddy that tows every day with his ram 2500 and he loves them. They look really good and he already has 40ish on them looks like they are wearing very well.
drwfaulk
by 06MidnightBlue » Fri Oct 19, 2012 7:57 pm
Either the Toyo MT or a 10 ply semi-aggressive all terrain equivalent. Your gonna want something with good bite. I would recommend the Toyo MT, the Toyo AT II, the Nitto Terra Grappler, or the Hankook AT/M. Make sure that whatever you get is a Load E (10 ply).
06MidnightBlue
by bgwolfpack » Sun Oct 21, 2012 1:28 pm
06MidnightBlue wrote:They have a 60K guarantee
They have no mileage guarantee. Only a 60 months first 25% warranty.
by Nakashige » Tue Oct 23, 2012 5:24 pm
toyo mt sitting ready to go on
Nakashige
Vendor
by 06MidnightBlue » Wed Oct 24, 2012 1:40 am
Good man.
06MidnightBlue
by 03envoy » Mon Jan 28, 2013 5:51 pm
Pics?
03envoy
by Nakashige » Wed Mar 20, 2013 1:44 am
I will post build thread for dd soon
Nakashige
Vendor
