Scored two sets of rims. Which would you run?
by BSalty » Wed Oct 27, 2010 5:34 pm
I got two sets of take off rims. Both sets are in great shape. I got em for almost nothing and plan to sell the set I don't use to help pay for the tires.
One is the polished 6 star rims from a GMC Denali. 17x7.5 w/ 5.5" backspace.
The other set is from a 1500 truck 16x7 w/5.5 backspace. Simple 5 star silver.
I was thinking of running the 17s with some BFG T/A KM in 255/75 17. But they are a bit on the bling bling side.
I would run a comparable 32" tire on the 16s and do some paint work on them.
Seeing as how a lot of you have run both 16 and 17 which is better? Is there really much difference? The price of comparable tires seems to be negligable.
And yes I already have the conversion spacer/adapters and my lift kit showed up today. :excited: Its all going on over the weekend!
BSalty
by Gordinho80 » Wed Oct 27, 2010 5:40 pm
16's with a 32" tire give you a little more sidewall.
What I would do is run the 16's and sell the 17's to someone with a Yukon or Tahoe who does not have polished wheels....
by MrSmithsTB » Wed Oct 27, 2010 5:46 pm
:Iagree: I much prefer 16" wheels and as long as you don't want to run larger than 285/75/16(33in), those will be just fine.
by Regulator1175 » Wed Oct 27, 2010 6:41 pm
Not sure if its an issue to you or not, but you will not be able to run the 16" with the center caps on. They thread onto the outside of the lugs, and they are different lug nuts then our vehicle uses. I had to take the plastic caps out so that I could get to the lug nuts and then glue the caps onto the rim itself.
Like I said, not sure if it matters to you, but I wanted to point it out.
by Zero » Wed Oct 27, 2010 7:10 pm
Since I spend more time on road then off, i went with the 17" rim. less side wall flex means better road handling. And I have never had an issue with not enough sidewall. So my set up works for me. Good luck on finding what will make you happy.
by bgwolfpack » Thu Oct 28, 2010 12:59 pm
Aren't 17" wheels called "Weenie wheels" for a reason? Without caps on the 16"s at least looks like your on a mission. :safari:
by Saxis » Thu Oct 28, 2010 1:28 pm
Except some of us don't have the weenie motor, and our larger breaks require 17" wheels. :raspberry:
Saxis
by BSalty » Thu Oct 28, 2010 2:49 pm
Hey guys thanks for the input. The only reason I thought of going with the 17s is I like how Gordinho80s truck sits. That is about perfect and he has the same lift mods I have. ( Imitation is the sincerest form of flattery right? :thumright: ) And I also like Zeros truck and you are both on 17s.
But alas I think I am going to run the 16s as I can get more $ out of the polished 17s. They are selling for $250-350 ish locallly and I only paid $100 for both sets of rims. That would pay for my spare. I already got a plan for the centercap issue. :coffee2:
Thanks for the help guys. :cheers:
BSalty
by bgwolfpack » Thu Oct 28, 2010 3:20 pm
Saxis wrote:Except some of us don't have the weenie motor, and our larger breaks require 17" wheels. :raspberry:
Touche
by fishsticks » Thu Oct 28, 2010 4:52 pm
Some of us with the weenie motor might even have a set of EXT caliper brackets sitting in our garage...........
Just sayin. :finger:
by bgwolfpack » Thu Oct 28, 2010 4:57 pm
Some of us might actually do something with them. Instead of just letting them sit on the bench next to the dirty rags. :raspberry:
by fishsticks » Thu Oct 28, 2010 7:20 pm
bgwolfpack wrote:Some of us might actually do something with them. Instead of just letting them sit on the bench next to the dirty rags. :raspberry:
Need rotors.... the cheap part of me is waiting until I need to do brakes again. :safe:
by Hatchet669 » Thu Oct 28, 2010 7:51 pm
i dont know about a larger break.. but i could sure use a longer one at work...
Hatchet669
by BSalty » Thu Oct 28, 2010 7:56 pm
:lurk: You guys are crackin me up. :viking: :party:
BSalty
by DJones » Thu Oct 28, 2010 9:11 pm
How much would you sell those Sierra/Yukon wheels for?
David
DJones
by BSalty » Fri Oct 29, 2010 1:40 am
I have the set listed for $250 locally. (Utah) They have all the center caps and lug nuts.
BSalty
by teebes » Mon Nov 01, 2010 2:29 am
I'd go 17s if you have the chance. Most tires in this size will be taller than the 16" equivalent and seem to be more readily available (new and used)! I've been watching CL like a hawk lately and 17" tires are everywhere. Plenty of sidewall with 34 or taller, too tires.
teebes
by BSalty » Tue Nov 02, 2010 7:55 pm
Well after getting no replies on my ad. I am going to black chrome the polished rims and run them. If I black chrome the rims I will do the chrome grill bar to match. That should look good. :woot:
BSalty
