Tire pressure thread
by bartonmd » Wed Sep 04, 2013 2:01 pm
navigator wrote:post 3 from that link brought images of tires from a top fuel dragster to mind
Yes, this is specifically the reason that dragsters use bias ply tires, even though radials are more stable and have better traction characteristics. With bias ply, you get a fatter, shorter tire for the launch, that turns into a taller (for gear ratio change) and thinner (for aerodynamics on an open-wheel car and rolling resistance) as speeds go up.
by HARDTRAILZ » Wed Sep 04, 2013 2:04 pm
Watch bias ply tires work in the rocks. Amazing how they conform.
You should watch the rock bouncers with the 43 inch SX most of them run. You will see them heat them up on the rocks on purpose to get the tire to act how they want. Crazy stuff those tires can do.
by TBYODA » Wed Sep 04, 2013 8:26 pm
I heard it explained a little different but think they were talking about the same thing but not such a technical description (was on tv) . IIRC they used the lower pressure tires so they would flex as shown below and cause less wheel spin from high torque at launch.
by TBYODA » Wed Sep 04, 2013 8:27 pm
HARDTRAILZ wrote:Watch bias ply tires work in the rocks. Amazing how they conform.
Like this... I googled "top fuel dragster tire distortion"
by Moots1288 » Wed Sep 04, 2013 8:32 pm
with 10000 horsepower and 6000lbs of torque.
by TBYODA » Wed Sep 04, 2013 8:54 pm
It is pretty amazing that you can get a square tire or pentagon at those speeds/ torque, etc. LOL
by Moots1288 » Wed Sep 04, 2013 9:00 pm
TBYODA wrote:It is pretty amazing that you can get a square tire or pentagon at those speeds/ torque, etc. LOL
Yes it is, the power they put out of those motors are pretty amazing too.
by Cable810 » Fri Sep 06, 2013 10:00 am
I've been running 38 on all 4 grabber at2 and have been wearing good.
