by navigator » Wed Sep 04, 2013 1:38 pm
interesting debate, If you think about it like this, the length of the tread never changes.
I think we can test this.
I think if you aired down one rear tire on one side and put a chalk mark on the tire and pavement and drove one complete revolution, make another mark on pavement and measure the distance.
You could then repeat the process with a full pressure tire and see if there is any difference in the distance.
I would think you would want to at least do the same axle to make sure the weight is similar. You might even be able to do the opposite side at the same time.
Another test might be to do all 4 at one time. Air down tires on 2 different corners. Compare front to back and tires on the same axle. Maybe do 40lbs in one tire and 15lbs in the aired down version.
