JamesDowning wrote:Ah-hah! Based on my experience, I wouldn't go over 32s on your 3.42 gearing.
You can, and many have, but your mileage will suffer on the highway because your torque converter will constantly be kicking out of lockup. As a result, you can also easily over heat your transmission.
This page helps I think: http://www.offroadtb.com/articles/tech- ... alculator/
jhberria wrote:Interesting discussion on actual vs. advertised tire size.
That being said, what are your thoughts on upgrading from my current 265/76/16 Duratracs (advertised as 31.7 inches, actually closer to 31) to 285/70/17 Duratracs (advertised as 32.8 inches, most likely closer to 32 flat, if that)? Feasible with the stock gearing?
boog2006 wrote:JamesDowning wrote:Ah-hah! Based on my experience, I wouldn't go over 32s on your 3.42 gearing.
So, no more than 32's on 3.42 gears....which measurement of 32's is that using? Rated? Loaded diameter? Circumference?
v7guy wrote:It's kinda like picking a girlfriend or wife.
