What do you guys think of the skid plate in designing?
by MD_trailblazer » Thu Feb 23, 2012 7:21 pm
Well not exactly for coca cola but the way I go in there isn't any posted signs and I asked the police and they said all they could do is ask me to leave as for Pasadena they are small easy trails except for one point were my tb gets on three wheels and it's off of markey neck blvd in glen Burnie area if you wanna meet up next wednesday or Thursday let me know
MD_trailblazer
by dvanbramer88 » Thu Feb 23, 2012 7:26 pm
Are you going to add an access hole for the oil drain plug? Or do you have to drop the whole skid to change the oil? PITA in my book..
by MD_trailblazer » Thu Feb 23, 2012 7:31 pm
dvanbramer88 wrote:Are you going to add an access hole for the oil drain plug? Or do you have to drop the whole skid to change the oil? PITA in my book..
I'm not sure...let me know what you guys want and I could probably make them to order
MD_trailblazer
by DirtyBacon04 » Thu Feb 23, 2012 7:49 pm
Well its kind of a PITA to change the oil filter with the skid on, IMO. 4 bolts. No big deal.
by dvanbramer88 » Thu Feb 23, 2012 7:52 pm
DirtyBacon04 wrote:Well its kind of a PITA to change the oil filter with the skid on, IMO. 4 bolts. No big deal.
Good point. I didn't even think of the filter.
by DirtyBacon04 » Thu Feb 23, 2012 8:00 pm
The hole is still a good idea, just to give the drain plug that much more room in case of a heavy drop. So the skid pan doesent jam up against the plug, risking you whole oil pan.
by dvanbramer88 » Thu Feb 23, 2012 8:05 pm
DirtyBacon04 wrote:The hole is still a good idea, just to give the drain plug that much more room in case of a heavy drop. So the skid pan doesent jam up against the plug, risking you whole oil pan.
Agreed. Worst case scenario, if you fall on and bend the skid, you could push the bolt right into/through the pan.
by MD_trailblazer » Thu Feb 23, 2012 8:10 pm
Agreed as well
MD_trailblazer
by bartonmd » Thu Feb 23, 2012 8:16 pm
The oil pan is stronger than you give it credit for... The drain plug does have a gusset on it, and the oil pan is a stressed member with the front differential mounted to,and going through it... Before I started making skids, the oil drain plugs held up to quite a bit of stress in the vertical, under the stock plastic skids...
by MD_trailblazer » Thu Feb 23, 2012 10:41 pm
I mean if I or someone bent 7/16" 6061 they would probably have had to seriously gotten some air and came down on a huge rock lol
But apparently fish is a hardcore Offroader so he'll have to get one and see if he can punish it
MD_trailblazer
by navigator » Thu Feb 23, 2012 10:45 pm
another thing about a hole is if you develop a leak it would kind of direct the oil there to help you spot it faster than when you change the oil.
by HARDTRAILZ » Fri Feb 24, 2012 12:09 am
Looks like an expensive piece I don't need and what's the support for the big front wing thing?
by MD_trailblazer » Fri Feb 24, 2012 12:38 am
The supports I'm working on...now im also working with the front suspension to try to get more with with new UVA and lca and newly designed steering knuckles
MD_trailblazer
by navigator » Fri Feb 24, 2012 8:04 am
if you are designing new steering knuckles consider building them to fit the TRE from a 2500 pickup.
Some of the member here have reamed out the stock knuckles to run them. They are much heavier than ours and I understand they are cheaper as well.
by MD_trailblazer » Fri Feb 24, 2012 8:07 am
I was already gonna do that I read that thread
MD_trailblazer
