Finally gettin' serious about the build
by TripleJman » Mon Dec 10, 2018 10:37 pm
Thanks for all the help from before, I've made a couple posts asking about suspensions parts etc, but now I know exactly what I wanna get.
I just need help choosing the best parts :lol:
2" lift, no more no less, maybe 2.5" front 2" rear , wheel SPACERS not adapters, because wheels are expensive :oops:
Replacing the front struts as well, flipping the uca ball joint thingy, and maybe replacing some other parts that are NEEDED.
So, BUDGET-WISE, whats the best 2" lift, BDS, Rough Country? Also where do I get MarkMC Liftmeister parts, because the website is down :/
So bassically, I'm just getting 32" tires w/ wheel spacers, new front struts, and 2" lift. What's the best options available?
TripleJman
by cpyonker » Mon Dec 10, 2018 10:58 pm
I went with rough country, no issues so far.
cpyonker
by Tricguy007 » Tue Dec 11, 2018 11:25 pm
https://supremesuspensions.com/pages/pr ... c~md_envoy I run just the front 2.5" with suburban XL rear springs and no rear spring spacers I'm currently running a 255-70-18 (32") tires on mine with no rubbing but did have to adjust the fender to the rear of the front tire
Tricguy007
Name: grant Huskelhus
by Trail X » Wed Dec 12, 2018 11:01 am
Liftmeister apparently is no longer selling lifts, but if you contact MarkMC directly he may be able to supply you with some wheel spacers still. I agree on what you're doing with spacers instead of adapters. The cost of wheels is hard to justify.
I had good luck with the BDS lift a while back, and experienced good tech support from them.
by TripleJman » Wed Dec 12, 2018 10:26 pm
So far, seems like i'll be purchasing the Rough Country 2" lift, getting wheel spacers from MarkMC, buying bilstein 4600's front struts from amazon/wherever, and installing all this myself (and flip the uca myself)
My back (with new shocks) shits alittle higher than the front, so I almost want to get a 2.5 front and 2" rear, so is there any place I could get a .5" block or something to add onto the rough country? or just buy a 2.5"f - 2.0"r lift? Thanks for all the help guys, I just want to make sure im getting the right/best parts for my TB :D
TripleJman
by Diacom » Thu Dec 13, 2018 2:16 am
Don't worry about the .5" rake, once you put a few things in the back it'll level out.
by Cody_S » Thu Jan 10, 2019 11:55 pm
Have you ended up installing this yet? I'm looking at the Rough Country set myself, and wanted to see how you like it.
WX4WCS
Back from the dead!
Old Envoy Build Thread
Cody_S
by TripleJman » Sun Jan 13, 2019 2:14 am
in just a couple days it will be
TripleJman
by TripleJman » Thu Jan 17, 2019 3:26 am
Rough Country 2" front and .75" rear lift/leveling kit is here, my wheel spacers will be here sometime today hopefully.
Does anyone know how much it would cost to pay a local mechanic to install the lift?
TripleJman
by Cody_S » Thu Jan 17, 2019 2:47 pm
TripleJman wrote:Rough Country 2" front and .75" rear lift/leveling kit is here, my wheel spacers will be here sometime today hopefully.
Call the shop for an estimate. Average mechanic prices are $80-100/hour, could be higher or lower depending on the shop. I'm not an expert by any means, but I'd guess that they'd probably bill 2 - 3 hours for the job. So worst case just going off of this, I'd prepare to pay around $300. But it's hard to say without knowing the shop. I would just call whichever shop you're looking at taking it to, let them know what you're trying to have done and ask for an estimate.
WX4WCS
Back from the dead!
Cody_S
