Removing bumper for bigger tires
by nicedude80 » Sat Feb 06, 2016 12:14 am
Hey,
I see that most people remove stock bumper when getting larger tires, but I wonder if it is necessary. I want to get a 3" suspension lift, and 1.5" spacers, so I should be able to fit 32" tires without removing the bumper, correct?
Jared
nicedude80
by jrivs4x4tb » Sat Feb 06, 2016 12:43 am
Yes, I had a 3" lift and 1.5" spacers with 32" tires and all that was needed was trimming of the plastic.
Sent from my LG-H901 using Tapatalk
Colorado springs where you at!?
jrivs4x4tb
by nicedude80 » Sat Feb 06, 2016 1:20 am
jrivs4x4tb wrote:Yes, I had a 3" lift and 1.5" spacers with 32" tires and all that was needed was trimming of the plastic.
Trimming of the bumper plastic, or the inside fender?? Just wondering, did you use stock rims with 32" tire, or did you get new rims?
nicedude80
by gotspeed1 » Sat Feb 06, 2016 1:33 am
I didn't trim at first with the 32s, bumper got ravaged. I then trimmed before the bumper got ripped off, however, the inner fender liners suffered at full compression. When I sold the truck, there weren't any fender liners left. For what it's worth, if you take you time and measure properly, trimming the bumper will not look ridiculous. With the bigger tires on there, it will look like it's supposed to be that way. :cheers:
gotspeed1
by jrivs4x4tb » Sat Feb 06, 2016 2:39 am
Inside fender, stock wheels and didn't need to trim anything from the bumper, I did completely remove the inner fender liner because its useless.
jrivs4x4tb
by Ole Blue » Sat Feb 06, 2016 2:18 pm
I have the 3" lift with 32's and done no trimming with no rubbing.
Ole Blue
by navigator » Sat Feb 06, 2016 7:46 pm
take a stroll through the build threads and look at all the builds similar to what you are targeting that still have the bumper covers.
I'm running about 4.5" of lift with 33's and still have my bumper. It is easier for those of us that don't frequent rocks and steep inclines to keep our bumpers than those that spend a lot of time there.
I did have to trim a few inches of fender liner and massage that one support bolt by the footboard.
You'll have to see what you need to do when you get it all together, they all vary some.
by nicedude80 » Sat Feb 06, 2016 10:40 pm
Yea, your right. Thanks guys. I just think that it should either have the original bumper, or a custom one, I think it looks odd when it is taken off.
nicedude80
by Cable810 » Sun Feb 07, 2016 11:00 pm
I only had to trim when I took the bumper cover off
by v7guy » Tue Feb 09, 2016 3:04 am
I ran 32s with the stock bumper and only the 3"lift for a good while without issues, I had to trim a small sliver, but you may not. I outline it in my build thread.
by SnowBlazer » Tue Feb 09, 2016 9:47 am
Don't mean to hijack the tread here but how big can you go with Mark's 2.5 kit and his spacers? I have 255/70R/16s on there now and those look little.
SnowBlazer
by HARDTRAILZ » Tue Feb 09, 2016 1:51 pm
SnowBlazer wrote:Don't mean to hijack the tread here but how big can you go with Mark's 2.5 kit and his spacers? I have 255/70R/16s on there now and those look little.
Seriously... the info is around and it is a complete BS hijack to serve only your own needs.
