Hey guys,
My truck needs a suspension overhaul so I figured I'd lift it up a bit at the same time. Right now the truck has Monroe quick struts on the front and I'd like to get OEM springs back in there when I do all this work. The ones that come on that setup seem to be super stiff as they are generic and not matched via spring rate.
My question is, is there a good aftermarket spring I could buy or should I just go with a new set from GMpartsdirect?
Nick.
