by v7guy » Tue Dec 27, 2011 1:04 am
Yeah, I'd reuse the stock ones if one of them didnt have a small hole in it. Do you know of anyplace we can get stock type replacements? Does anyone have some trashed stock shafts with intact boots I can buy?
I was looking at CV axle I have here and I was wondering if a outer CV boot would work on the inner. The outer has 5 ribs instead of 3 and by its very nature is made to flex more because of steering. The tripot is about .25" bigger than the outer joint though (tripot is 3.46 outer is 3.72). Dorman lists a 614-004 boot and a 44077 silicone boot but they both say they fit larger than 3.5". It would probably be fine and they both have 5 ribs and should be more flexible (if the pictures are accurate), im just not sure how the bottom bunched up parts of the boot would react with even more material being crammed together.
I only need these to hold together through the winter. I'll have more weight on the front in the spring.
