Big Silverado Mirrors installed
by RimoniManu » Sun Apr 08, 2012 10:03 pm
I've been wanting to do this mod for a while cause I hate how small the TB side mirrors are. I bought a pair of mirrors from craigslist for $20. The mirrors came off a 2005 Silverado 2500hd, they are power and heated.
Removal was very easy. Very carefully pry up the power window switch assembly. There's no screws holding it down, it just snaps into place. Disconnect the mirror wire harness.
In this picture the mirror connector is the third from the left:
Next, according to Chilton you need to removed the entire door panel. There are two bolts that hold the panel on the door, which you can see one when you remove the power window switch assembly and the other is hidden.
Here are the two bolts circled:
You don't need to remove the door panel though. It takes too long and you may break some of the snaps that hold the panel to the door. All you need to do is pry the corner where the mirror is located just enough to get to the bolts. Remove the foam insulation and remove the three bolts. When you're pulling the mirror off and it feels like its getting hung up on something, look inside where you removed two of the bolts and there is a small "hook" holding the mirror.
This is where the hook is:
Now it's time for the fun part of wiring the new mirrors. Don't cut any wires until you have figured out exactly how you want to do it. The mirrors I bought only had about 3 inches of wire left from when the guy cut them, so it just depends on you and your new mirrors. That being said I also don't know what type of mirrors you're getting and what style of plug they have, that's what makes this so fun isn't it.
I've looked and looked, even went to a Chevy dealer and with no luck I was unable to find a wiring diagram of our TB mirrors. So I had to do it the hard way. While I was on an offroading trip I lost traction and slid into a tree and somewhat crushed my passenger mirror. It still worked but the plastic was cracked and the cover had fallen off, so what I did was I cut it open for all of you too see.
Here's what's left:
Here are the important parts. Just an FYI, my TB is a 2002 EXT so you may not have all the options mine does. The mirror(those two prongs on the mirror are for the heated mirrors only), the mirror housing along with the mirror adjusting motor, and what I'm holding is what the the mirror mounts onto and allows the motor to adjust the mirror angle.
This is the back of the motor. If you were to take off your own mirror glass you would have to remove the motor in order to get to these wires.
The insides of the motor. When this is in the housing it's not laying up and down like in the picture, it's turned about 45 degrees. Inside there are two electric motors, one gear per motor, and above the motors is a Printed circuit board. The PCB is for the memory mirrors.
Here's a picture showing how the mirror attachment fits in the motor housing.
This is what the mirror physically attaches to. The two straight legs are actually plastic screws. When you want to adjust your mirror up/down/left/right the motor spins the gear, making the leg screw up and down. The other two square looking legs are for the PCB board/memory feature.
Just to give a better idea of what I'm talking about, you can see how it fits together.
Here are all the wires that you'd find inside the mirror housing. From left to right you have, PCB connector for memory mirrors, electric motor connector, turn signal connector, and the two black wires are heated mirror connectors.
The mirror connector has two rows, labeled A and B, and eight rows, labeled 1 through 8.
I made this diagram according to the row and column labels found on the connector. To figure out what wires did what it was just a process of elimination and testing with a voltmeter. Here is what I found
You'll notice that there is only one red wire on the connector but there are two red wires that connect to the electric motors. Thats because inside the mirror housing the wire splits into two.
I was unable to find a wiring diagram for my new silverado mirrors so I just had to guess and try things out. I could tilt the mirror glass to look behind and see which wires went where so that helped. Easiest thing for you to do is find a diagram for your mirror. If you can't find one you'll just have to try things out and see what it does. The mirrors I bought the driver mirror was wired slightly different than the passenger mirror. Here's what I found and yes it works, and for the driver side because the stock connector only has one red wire(the up/down/left/right (-)), I connected the two yellow together.
One problem I faced and you will face too is that the bolt holes to attach your new mirror wont match up. This is my new mirror and I layed my stock backing foam on it to see where the holes lined up. Two are very close but one is off about an inch.
To figure out where i needed to drill a hole I placed the backing foam from my new mirror where it would mount like this picture. And yes I know the foam in the picture is from my stock mirrors, I forgot to take a picture when I did that.
Another problem I encountered was where I needed to drill the hole. It's hard to explain exactly what I mean so I'll just show you.
The bolt will be too close to the door frame that I wouldn't be able to install the nut. To get around this I cut a little of the frame.
I also filed the top bolt hole a little so I could rotate the mirror to fit the lines of the vehicle, that way it looked stock. Now that it was time to install my new mirror I had a decision to make; to use the new mirrors backing foam or use the stock foam. Here's why I had to decide:
There's a gap and it doesn't look appealing.
After all the hard work I'm very pleased with the final result. I love the bigger mirrors and have full functionality, plus if you didn't know any better you'd think they were stock.
Here's a comparison of what stock view looks like vs new view:
Hope you like the mod. It's actually very easy. I did the hard part of figuring out the wiring, now all you need to do is re-wire and figure the mounting. Happy modding.
RimoniManu
by Mudwheelin » Sun Apr 08, 2012 10:20 pm
Wow nice job man! Not crazy about that gap though. Any idea how you could fill that in a bit?
Build Thread:
viewtopic.php?f=25&t=2349
Mudwheelin
by RimoniManu » Sun Apr 08, 2012 10:33 pm
Let me go take a pic real quick
RimoniManu
by RimoniManu » Sun Apr 08, 2012 10:39 pm
Here is how I have it right now. I'll probably do something a little different though. I may try and fit my cut up mirror around it somehow.
RimoniManu
by Nakashige » Sun Apr 08, 2012 10:43 pm
black silicone or sand-able body filler
Nakashige
Vendor
by Mudwheelin » Sun Apr 08, 2012 10:50 pm
That looks much better now. Nice install dude. I like the look of them.
Build Thread:
Mudwheelin
by RimoniManu » Sun Apr 08, 2012 11:04 pm
Thanks, the gap looks ok, but still gonna try and make it flow better. I'll post a pic when I get it done.
RimoniManu
by Trail X » Mon Apr 09, 2012 8:33 am
Mirrors look good!
Although, maybe you should have spent that money on new tires!?!
by hobbstisdaman » Mon Apr 09, 2012 12:07 pm
I like. Have you ever posted on here about your snorkel install? Would love to see about it.
hobbstisdaman
by RimoniManu » Mon Apr 09, 2012 12:07 pm
Hahaha!! Couldn't pass up on a set of mirrors for $20. I do have a new set of tires though.....36" military hummer tires along with the 16.5" double beadlock rims. Just finishing up my axle build and then I'll be putting them on.
RimoniManu
by RimoniManu » Mon Apr 09, 2012 12:09 pm
I posted on trailvoy about my snorkel build. Haven't been on that site for a while though.
RimoniManu
by fishsticks » Mon Apr 16, 2012 1:11 pm
I'll admit, some of your ideas just make me :facepalm:.
This one I like. Well done.
by RimoniManu » Mon Apr 16, 2012 1:16 pm
fishsticks wrote:I'll admit, some of your ideas just make me :facepalm:.
Lmao you must be talking about from trailvoy lol. Just dreamin stuff up. But thanks for the compliment.
RimoniManu
by Mudwheelin » Mon Apr 16, 2012 7:45 pm
Good eyes on the tires James. Just noticed that lol. I would really like a write up on how you did that snorkel! Looks great man. Have you figured out that gap issues with the mirrors yet?
Build Thread:
Mudwheelin
by Dirtyd » Wed Jun 27, 2012 1:08 am
LOVE IT!
Would Silverado extended mirrors like these work the same?
You Only Live Once
Dirtyd
by mikekey » Wed Jun 27, 2012 8:23 am
I love this mod. The gap fitment isn't too terrible and could be corrected with a properly cut piece of rubber and glue.
I personally want to do this, I don't have the best of vision and the mirrors on our TB are only slightly more usable IMO than the horrible mirrors on my Corvette which are utterly useless.
Time to search ebay and see if I can snag a set.
by cbbryan » Sun Jul 01, 2012 5:33 pm
Very Nice! I want to do this now. I wonder if they any similar to what my buddy had on his RAM 2500? They could be turned vertical or horizontal; a pretty neat feature I believe could come in handy?
cbbryan
by RimoniManu » Thu Jul 26, 2012 1:35 am
Sorry I havent been on here for a while; Dirty the install would be very similar. You'd just have to measure the bolt holes and drill a hole or two and then rewire if they're electric.
RimoniManu
by Cable810 » Thu Jul 26, 2012 9:38 am
Dirtyd wrote:LOVE IT!
I know Kuchar did that with the mirrors you linked to!
by Nakashige » Thu Jul 26, 2012 1:29 pm
Might be doing this and putting tow mirrors on the duramax
Nakashige
Vendor
