UCA's
by White04 » Mon Jul 23, 2018 5:34 pm
Hey all, this is my first post. I am in the process of lifting my blazer, just by putting in the Bilstein shocks and struts, the Moog springs 81114 in front and the z71 in back. It seems like that is what everyone suggests. I want some lift but not a lot. What I can't seem to find on here is whether or not to flip the UCA's? Are there positives or negatives for it? Do I need to do it or will I have issues down the road?? Oh and I'm putting in some 1.5 inch wheel spacers. I'm new to all this so please bear with me... Thanks a lot
White04
by Diacom » Tue Jul 24, 2018 11:59 am
You know the 2nd sticky, right here in Lifts/Suspension? Might want to give that a read.
by mason10198 » Tue Jul 24, 2018 12:08 pm
Short answer: Yes.
Long answer: Yes. And you need to read.
by Miltman » Tue Jul 24, 2018 1:45 pm
May as well do it now. It will save you time later of going back and doing it again
Miltman
by White04 » Tue Jul 24, 2018 5:36 pm
I saw the sticky as soon as I hit post..... was like omfg DUH!!!...... sorry about that and thanks for the info.
White04
by White04 » Wed Jul 25, 2018 6:16 am
Should I replace my CV boots too while it's torn apart? They don't look bad. I was reading they tend to leak after the lift.
White04
by mason10198 » Wed Jul 25, 2018 11:40 am
You're better off replacing the whole CV than trying to replace boots. Not worth it IMO.
by Miltman » Wed Jul 25, 2018 1:28 pm
Miltman
by BC backroader » Wed Jul 25, 2018 2:05 pm
Double clamp the boots when you lift, as they tend to pop off and leak if you don't. I read that on this forum before lifting mine, added large hose clamps with the lift, and had no problems in the 3 years that I had it with the lift.
by White04 » Wed Aug 08, 2018 5:20 pm
Coming together slowly. Moved to yard to clean up all the damn rust that fell off in the garage. Need... More.... money!!!!
White04
